Oil pump question
Old Oct 1, 2015 | 03:51 PM
jaxdwg's Avatar
jaxdwg
Default Oil pump question
I just got a Fueling 7010 oil pump and it has no oring or machined groove for the oring on the face of the pump. I have tried all day to contact them, but their phone system sucks big time. Does anyone know whether this pump actually runs without a face o-ring?
Old Oct 1, 2015 | 04:12 PM
Redbeard719's Avatar
Redbeard719
The 07+ Touring engines do not have the large o-ring between the pump and cam support plate.
Only the TC88 engines have that...
Old Oct 1, 2015 | 04:30 PM
jaxdwg's Avatar
jaxdwg
This is an 03 tc88 and according to the Dennis Kirk site it is an exact match for that machine. I'm not going to put it in until I know for sure all is correct. Thanks for your input
Old Oct 1, 2015 | 04:34 PM
Redbeard719
It's possible to upgrade to the newer style oil pump and cam support plate that eliminates the o-ring. But then you'd also need to get new conversion cams to fit the engine case and new support plate.
Does the Feuling oil pump require the use of their support plate? If I recall, they do offer a support plate.
Old Oct 2, 2015 | 01:44 PM
jaxdwg's Avatar
jaxdwg
Got an email from Fueling and he told me they had dropped the o-rings in their pumps and no longer used them on the pump faces. I installed new cam brgs, new tensioner shoes, mine were about 65% gone, at 35.5k, and the new OE+ pump without totally removing the front pipe. The new pump holds about 11 psi (gauge) when warm, at idle,and a bit above 32 psi at speed. Although it wasn't absolutely necessary to change out the shoes, my piece of mind is satisfied now, and I can do a Long putt with my brother, without worrying about it. BTW, runout was.002"
Old Oct 2, 2015 | 02:39 PM
bagman1's Avatar
bagman1
Are you aware the max runout on a Feuling pump is.002? At least on the 07+ type. Im sure the tight clearances is why they dumped the orings.
Old Feb 28, 2016 | 10:12 AM
vinnib's Avatar
vinnib
I did the cams in my 09 EG last year. It had the O-ring between the pump and plate. It is a 96". However there is a diff between the standard engine cam plate, and the SE cam plate. I don't for sure but the SE cam plate might not have that o-ring.
Old Feb 28, 2016 | 11:14 AM
msocko3's Avatar
msocko3
Interesting, there isn't supposed to be an o-ring between the pump and plate on the 07 and later touring, makes no difference whether its 96", 103" or 110". If you had an o-ring, someone had it apart and got a case of head in the assitis, because it's not supposed to have one.
103Eagle
Milwaukee Eight (M8)
15
Mar 8, 2019 10:42 AM
Gtop
Oct 31, 2018 03:38 PM
foxtrapper
Sep 29, 2013 09:36 PM
hduc2005
Exhaust System Topics
Jun 19, 2008 10:50 AM
rdeitel
Jan 20, 2007 09:48 PM
