Rear engine mount
Old May 5, 2007 | 11:18 PM
wildside41's Avatar
wildside41
Default Rear engine mount
Need my rear mount changed on my 01 electroglide. Is this a big job? cAN SOMEONE RUN ME THROUGH IT? How much would it cost at a dealer? Thanks for any info.
Old May 6, 2007 | 02:27 AM
hogdoc's Avatar
hogdoc
Default RE: Rear engine mount
Rear? Do you mean the swingarm bushings? The swingarm pivot shaft runs through the blocks that the pass pegs mount to, through rubber/steel doughnuts behind them,then the swing arm bushings, andthen the back of the tranny. This is what your rear mount consists of. the swing arm bushings are what usually wear out. Not a bad idea to replace the doughnut at the same time. It is a pretty big job, rear wheel, pivot shaft, and swing arm must be removed. The bushings are pressedout ofthe swing arm. They are pressed back in to a specific depth, and then everything reassembled. You should also check Vehicle Alignment after all is done. Also a fairly big job if you've never done it. And you need two STRAIGHT 8' aluminum square tubing to check it. DO NOT believe it when someone says just use 8' flourecent light tubes, they're not Straight. You'd be looking at about 4-5 hours at a dealer including alignment if needed , less if alignment is ok. Hope this helps.
zamiam
Oct 13, 2015 08:08 AM
slack20
May 28, 2009 08:42 PM
ezglide1450
Jul 15, 2007 12:24 PM
500MAG
Exhaust System Topics
May 15, 2007 07:34 PM
magna3500hd
Jan 7, 2007 08:21 AM
