Help Needed
Old Oct 23, 2015 | 12:48 PM
Princeamir175's Avatar
Princeamir175
6th Gear
Default Help Needed
Hi Guys,
I have a 2014 FLHRC Road King. I want to install a leather tour pack on it but the parts guys at the HD dealership says the rack thats fits it doesn't fit the 2014 FLHRC and there isn't a rack that does. I looked online and I can't seem to find any.
If any of you has installed a leather tour pack on a 2014 FLHRC please let me know How.
I also installed a visor from HD on the main headlamp but there remains an ugly gap at the bottom. I've seen pics online with the visor completely closed. Does any one know how its done?
Thanks guys. I appreciate your help and advice.
Old Oct 23, 2015 | 01:54 PM
Gwaxley's Avatar
Gwaxley
This is the stock rack on a 14 FLHTK with the TP removed. There's a bunch of slots to mount whatever? I don't know how the leather packs mount or how the FLHRC has to mount but thought id show you the stock one and if it may help?
Old Oct 23, 2015 | 02:27 PM
NODYNA's Avatar
NODYNA
If HD does not like the way a part will loo
k like on a model they dont list any compatabiliy. Your bike is not diferent from a standard RK. Measure the mounting points for the rack to verify it will fit.
Old Oct 23, 2015 | 02:41 PM
Magnut1's Avatar
Magnut1
You can drill any of the holes you want on the bottom of the tourpack. GWaxley showed you a standard mounting rack. You just put the rack on , set the tourpak on, get it where you want, then take a sharpe or white grease pencil and go from underneath and mark the box through the holes , flip it over onto a blanket, and drill away. It is quite a rush, knowing if you don't do it correctly, you just wasted $800.. LOL
Old Oct 23, 2015 | 09:05 PM
Ragtop's Avatar
Ragtop
The headlight trim ring can be tightened enough to close the gap.
Mine was the same way when first put on. I had to tighten the hell out of
it to get it to close. That little screw will take a lot of punishment.
lookslikeahog
Jun 30, 2022 02:20 PM
CornbredNE
Jun 8, 2012 10:17 PM
vet767
Feb 19, 2011 03:43 PM
Mike1397
Jun 3, 2008 03:09 PM
Jonpaul
Jan 5, 2008 03:40 AM
