Touring Shocks
A high performance motorcycle also has a very firm suspenion.
A motorcycle has an advantage for air flow. A sports car designer needs to worry about air flowing under the car. A motorcycle can sit high and still handle good. Look at sport bikes and motorcycle racers. They sit very high.
If you lower your cycle and have only 2 inches of travel and hit a dip your kidneys would be telling you that you should have crawled down that dip. On the other hand if you have 4 inches of travel you can also have soft suspension and still hit that dip at speed. You now have 4 inches before you bottom out.
If you have 4 inches of travel and want soft (luxury) suspension, you can still hit that dip at speed.
My point is if you have lots of travel you can have you suspension firm or soft and you are much less likely to bottom out. More travel will appease the performance riders and the smooth luxury touring riders.
Let me say this loudly: I agree there is more to suspensions than lots of travel but my point is that if you have more travel the shocks can be much more forgiving.
EDIT: Also let me add "forgiving" may not have been the correct word. There is A LOT more to suspensions that soft for cruisers and firm for fast sporty riders.
As a simple example, bearing in mind that Howard's Ohlins have been mentioned already, when I discussed the options with him he recommended #3 for Mrs B and I, rather than #2 with longer travel, simply because the damping of the #3 is better than the #2. We ride close to the max weight of our Glide, yet we have never ever bottomed out with our #3s and enjoy a superior ride to all previous shocks.
