Stabilizer link problem
Old Oct 26, 2015 | 09:17 PM
kevinb62's Avatar
kevinb62
Default Stabilizer link problem
Has anyone replaced a stabilizer link (dog bone) on a '15 rgs ?
I was try replace stock for the black one and can't seem to get it lined back up.
What is the trick?
Old Oct 26, 2015 | 09:42 PM
btsom's Avatar
btsom
Isn't the length adjustable? How does the length of the new one compare to the length of the original? Or is it a problem getting the bolt through the hole in the new link, you don't indicate the problem.
Old Oct 26, 2015 | 10:44 PM
wscott's Avatar
wscott
What is the trick?
If your reffering to the link on top front of motor when its removed the motor will move/shift a very small amount ,but its just enough to cause last bolt to not line up,been there done that.
I used a piece of 1"x3" wood to leverage motor just a tad to line the last bolt up so it doesnt cross thread .
I wedged the wood under the tank onto valve cover (used a fiber cloth between tank & v-cover) on front cyl and just used a little trq/pressure on the wood to move/ leverage the motor a tad to line up the last bolt well enough to not cross thread the bolt.
I did this coming from right side of the bike as sitting on it so would be moving the motor a tad sideways and not front to back.
Again,you should not have to manhandle / use much muscle to leverage the motor a tad to line up bolt to thread easily.
Scott
Old Oct 27, 2015 | 05:34 AM
lp's Avatar
lp
Make sure you'er doing this while the bike is straight up on a jack.
Just easier since the engine is not leaned over.
Old Oct 27, 2015 | 06:19 AM
grbrown's Avatar
grbrown
Wink
The 'trick' is to understand what you're messing with! When the bike is on the jiffy then the engine is using that link to keep itself in alignment with the rest of your bike. As lp suggests, use a lift to keep your bike vertical, when the new link should fit without any problems.
To better understand the rubber mount system of your bike, of which that link is a part, read the opening post in my bagger wobble thread.
Old Oct 27, 2015 | 10:06 AM
kevinb62's Avatar
kevinb62
Thanks for the replies everyone, unfortunately I've tried most everything
that was suggested. Going to sit back, take a break and go at it again a little later.
Old Oct 27, 2015 | 02:12 PM
wscott's Avatar
wscott
You motor must have moved quite a lot if you could not et hole/threads lined up doing whats been suggested here.
Maybe you have a defective motor mount on your new 2015 bike allowing the motor to move too much giving you problems with bolt aln.
Scott
writeman
40
May 10, 2020 06:06 PM
Superchick
Engine Mechanical Topics
Sep 18, 2014 08:42 AM
Michael Miller
Exhaust System Topics
Jun 13, 2011 02:29 PM
RidemyEVO
EVO
Feb 16, 2011 05:11 PM
THE YETI
Jul 16, 2009 11:30 PM
