Would someone tell me why wheel cleaner you buy at any auto parts house says not to be used on motorcycles. I would bet if you go to any motorcycle store and buy wheel cleaner for motorcycles the chemicals would be no different than wheel cleaner you buy at the auto supply stores. What is the difference between chrome on a car wheel and chrome on a bike wheel? Would anyone use chrome wheel cleaner on chrome pipes or any other chrome part?
Harley wheels are not coated, thats why I take them off and have them
powder coated clear..As I am too old to be cleaning wheels after ever ride.
That raw cast aluminum that has NO coating of any kind.....tenn
easily the most neglected part of my bike. I just don't care enough to polish the lip of each rim . Id imagine some of the chemicals could damage the uncoated surfaces
They make wheel cleaners for different types of wheels, i.e., uncoated aluminum, polished, painted, chrome, clear-coated, etc. Selecting the appropriate cleaner for your type of wheel is important. That said, I have never seen a "not for use on motorcycles" warning on any of the cleaners I've used.
The exception may be on some one-step cleaner/conditioners because those types leave behind a dressing that will compromise traction if it gets on the tire tread. Most, if not all, "tire dressings" have a "not for use on motorcycles" warning on them for this same reason.
If you're using a straight cleaner I see no problem. If you have any concern after using a wheel cleaner you could always clean the tire tread with a rag dampened with mineral spirits, lacquer thinner, etc., to remove any unwanted residues.
I like to go as mild as I can on cleaning my chrome spoke wheels.
Thus far, all I have ever used on cleaning chrome is Maguires, the same soapy solution I use on cleaning the entire bike. Westleys on the WWW from time to time, and only if needed.
I use the appropriate (aluminum, chrome) spray cleaner on my wheels.
I then rinse with warm water, then use Dawn dishwashing detergent on my wheels, and then dry them with a terry cloth towel.
I also use soft bristle brushes for the nooks and crannies.
I have a "bagger" and that rear wheel is a b*t*h to get and keep clean!
