Valve stem replacement
Old Nov 1, 2015 | 06:43 PM
1690Mike1's Avatar
1690Mike1
Default Valve stem replacement
Question for the group: Is it normal for a shop to leave the old valve stems in when the tires are replaced? The reason I am asking is that my local shop left the old ones in. I had a slow leak in the rear and since the tires were nearly worn out I just had them replaced. Needless to say it's the valve stem and not the tire itself as I found out the hard way. I mentioned it in passing when I dropped the bike off but didn't make much of it since I assumed they would install new valve stems anyway. Thanks to all in advance
Old Nov 1, 2015 | 06:50 PM
Eunoterpsia's Avatar
Eunoterpsia
Your local shop should have replaced the valve stems :-( Perhaps you should call the local shop and ask if it is common practice to leave the old valve stems in... if not... explain your situation and see what they intend to do to remedy the situation.
Old Nov 1, 2015 | 09:22 PM
Streetrunner's Avatar
Streetrunner
Just had new tires put on and assumed they were going to put new valve stems so I didn't even mention it to the service department. To my surprise they left the old valves in. Lazy!
Old Nov 1, 2015 | 09:33 PM
Dionicio's Avatar
Dionicio
Replacing the valves stems is a standard procedure when installing new tires. Sounds like someone is trying to save a few bucks.
Old Nov 1, 2015 | 09:59 PM
Eunoterpsia
Seeing how you have to have the skin removed to replace the valve stem... Its a good time to buy 90 degree valve stems!
Old Nov 1, 2015 | 10:01 PM
ReidRik_Von's Avatar
ReidRik_Von
Indeed. I have the same 90 degree valves on my ride. So much easier to check the pressure.
Old Nov 2, 2015 | 02:30 AM
tfi racing's Avatar
tfi racing
If a shop is that cheap they won't change a valve stem on a tire change,I would be really concerned about what else they are cutting corners on...
Old Nov 2, 2015 | 03:04 AM
2black1s's Avatar
2black1s
I know in the automotive field it's common to replace valve stems during a tire change. I'd assume it's the same for bikes.
That said, I change my own tires and have NEVER replaced a valve stem on either of my bikes and they both have 75,000 + on them. Regardless of what the standard industry practice is I feel that replacing valve stems is completely unnecessary unless the stem exhibits some form of damage.
Old Nov 2, 2015 | 07:59 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
I go with new tubes and liner at each tire replace. (Spokes)
On autos, many people look at the condition and age of the stems. High mileage driven tires in a relatively short time that the stems still look good, heck, run 'em some more.
Generally, as a rule, quality tire shops will replace the stems EVERY TIME.
May I suggest to the OP: YOU MAKE THE CALL. If you want them replaced, tell them. Some keep up with them, and have them replaced every other time. On vehicles, getting the right length stems are very important, to ease access and/or reduce bending the stems over for checks which will lead to cracks some times.
Check the stems over as part of your regular tire inspections, and ride safe!
Old Nov 2, 2015 | 08:03 AM
Uncle Larry's Avatar
Uncle Larry
A common sense answer. What a concept. :>)
