Indeed. I have the same 90 degree valves on my ride. So much easier to check the pressure.
I pull the wheels myself but have the shop mount and balance. If they ever pulled my 90 deg stems and REPLACED them with standard valve stems, I WOULD REALLY BE PISSED!
I'm on my 3rd rear tire and the first 2 times the shop didn't change the stem. The stem started to leak so I bought a metal steam for $2 and had them install it with my 3rd new tire.
Last time I dropped off a tire it was a nightmare. I taped the new valve stem to the new wheel over the valve stem hole. They did not install the new stem, instead they taped it back on the tire, stated I did not ask for it to be installed. Same wheel/tire, now with the new stem is half flat when I got it home. They did not use the washer under the nut and the stem leaked from not being tight enough. Next tire change will be at home with a No-mar.
Called the shop and they told me that they normally do not change the valve stems. They said they will replace the bad one and not charge me for the tire removal. So all and all a happy ending. Thanks again
