Speedo Question/Problem
Old Nov 4, 2015 | 03:11 PM
Jerry1834's Avatar
Jerry1834
Default Speedo Question/Problem
Dealer installed Digital/Analog type (70900072) and it went belly up last night - get the red idiot light but nothing else - no OD - no Tack - no dash lights no speedo.
So I check for voltage etc and everything is good the the speedo plug - So must be the speedo which by the way was getting moisture under the glass the last few weeks..
New speedo (70900072a) followed instructions and it will not download from the data port hookup....it lights up but gives No speed and V error in the window...
Instruction are pretty clear and the trouble shooting guide didn't help - Only thing I can think of is the old speedo is dead and the new is trying to read it and can't.
Any suggestions?
Jerry
Old Nov 4, 2015 | 05:27 PM
Roadflyer's Avatar
Roadflyer
Any suggestions?
Jerry
Dry your old speedo out really well with a hair dryer, it might start to work again.
Old Nov 4, 2015 | 06:47 PM
p51bombay's Avatar
p51bombay
It's not reading the old speedo - it gets the mileage from the ecm. Are you sure you have the right plug when you attempt to transfer mileage?
Old Nov 4, 2015 | 08:01 PM
GTK's Avatar
GTK
The old speedo remains connected to speedo plug while you download info from ECM data plug to new unit.This is not real clear in instructions.
Old Nov 5, 2015 | 05:33 AM
Jerry1834's Avatar
Jerry1834
Thanks for the replies!
1) Did the Air Dryer first thing - NG
2) Left the old in place
3) I have used the Data link plug before
4) Wasn't sure if the old speedo and ecm had to work together for the download.
Was thinking an ecm problem but bike runs like a 'Top'.
Will attach the analyzer to the data port and see if I see any codes pop up.
Also emailed the MFG in Switzerland but haven't heard back due to the 6 hr time difference. Local HD tech never had a issue but hasn't done to many....
Old Nov 13, 2015 | 08:06 AM
Jerry1834's Avatar
Jerry1834
Per HD you need the old original speedo to get sometype of ID that is set at the factory....Good for extended warranty they got it now....
So never get rid of that old speedo if you do an upgrade....
JohnnyLytton
Electrical/Lighting/Alarm
Jul 17, 2015 12:01 AM
Ryan Lee Brasher
Jun 24, 2014 09:07 PM
Dlz811
Mar 22, 2014 01:51 PM
bagman1
Jun 18, 2013 02:54 PM
djl
Exhaust System Topics
Dec 1, 2012 02:00 PM
