Footboard bracket drags before footboard
Old Nov 8, 2015 | 10:20 PM
Sedonastrider's Avatar
Sedonastrider
Default Footboard bracket drags before footboard
It seemed that the footboard dragged before the footboard bracket did in the past. I did the extended reach rider footboard pans (1" forward) and the footboard bracket spacers (3/4" out). Those mods have been on for a while, but my riding style hasn't changed. I guess the footboard going forward has allowed less of the footboard to grind first?
Anyway, when I felt the lever effect from the bracket grinding, I stood the bike up immediately. I was going about 15 around a 90 degree right hand turn. Am looking for ideas on peg feelers that sport bikes have for the unlikely event I get into it that hard again. Maybe there are aftermarket brackets that are more ideal. I did find these:
http://www.tallboyscycles.com
Open to constructive suggestions and not so much lectures about riding it a little too hard. Below are some photos showing what was hitting and how little the floorboards were in road contact.
Old Nov 8, 2015 | 10:53 PM
ROCKOUT Rocker Products
Sponsor
Floorboards for the Limited Low & Ultra Low models have what you're looking for... little warning tabs.
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Nov 8, 2015 | 11:29 PM
Ragtop's Avatar
Ragtop
You have already worn off the low spot, so should be good to go now.
Old Nov 9, 2015 | 12:03 AM
Sedonastrider
Very cool info there. Thanks
Old Nov 9, 2015 | 12:07 AM
Sedonastrider
Interesting perspective. Only thing is the other side is not ground down... And I prefer not to get that triangulated lift off experience again
Old Nov 9, 2015 | 12:29 AM
Kayakeur's Avatar
Kayakeur
From: Eastern foothills of Shenandoah Mountains, Virginia
FLSTC Heritage EVO 99
Scrapes all too easily. Bought 3 months ago knowing it is low, partly because it is low.
Until then riding 05 XL883C, 4.4" clearance, which I hardly ever scrape.
imo,scraping the pegs takes weight off the tires at the worst possible time, a sharp turn. Cool-ish knowing you are that close to the edge but I'd rather be able to lean farther.
Still have the Sporty Sport Glide . . . . and still want the big twin bagger.
Ahhh, First World Problem.
Old Nov 9, 2015 | 12:38 AM
Sedonastrider
I hear ya there about the edge. Feels weird to keep the bike upright and lean off like on a sport bike. Although, it really can corner well when you do that
Old Nov 9, 2015 | 12:48 AM
Sedonastrider
I found this thread about the feelers that come on the low touring models that had some info about them not fitting:
https://www.hdforums.com/forum/touri...eet-glide.html
Thought I'd post it to further this thread
Old Nov 9, 2015 | 06:55 AM
Sponsor
Good info, thanks. I just assumed all the floorboards were the same.
Old Nov 9, 2015 | 07:42 AM
Buelligan666's Avatar
Buelligan666
I and a lot of others here use the Kuryakyn relocation brackets. They don't move the mounts out away from the frame, only the floorboards. They are 1" out and 1" forward. This helps eliminate dragging hard parts.
