NO front brakes!
Old Nov 18, 2015 | 07:52 AM
grbrown's Avatar
grbrown
Our hydraulic systems are not sealed and DOT4 is hygroscopic, meaning that it absorbs water. The reason H-D used DOT5 for so long is that it isn't, unfortunately it doesn't like working with ABS. Changing brake fluid should be done at regular intervals, every 2 years IMHO and experience.
That can mean that when changing say brake pads it is not wise to simply pry back the pistons, as the system may become over-filled. I also routinely flush my brakes when changing pads.
Old Nov 18, 2015 | 08:37 AM
smithbrl's Avatar
smithbrl
I imagine that could put a rider in a pretty tight spot if it happened while riding. Did this happen all of a sudden or did you experience any tell tale signs before it actually froze up?
Old Nov 18, 2015 | 09:21 AM
SSteve's Avatar
SSteve
As it turns out there was warning, twice while riding in one day the front brake got stiffer, had to squeeze harder for results. It went away, then later that day a little more stiffer. By the end of the day at home the front brake was normal. Brakes were fine for 2 weeks then wham, locked. A hydro lock is way different than a spongy or a soft weak brake where the lever moves and the bike slows/stops slowly or seemingly not at all. With the hydro lock the lever was solid, absolutely no play or movement. Glad it wasn't both at the same time. Rear brakes couldn't be better, never even a lick of trouble, only my fronts.
Old Nov 18, 2015 | 09:34 AM
SafetyMan's Avatar
SafetyMan
Have you written the letter yet?
What I see from reading this thread, and tell me if I'm wrong...
You bought a USED bike 2 years ago, and have not flushed the system since you owned it, and do not have any documentation that it was ever flushed per the manufacturers 2 year guidelines.
As far as you know, that fluid could be 8 years old...
I keep records of everything, and the guy that buys from me, gets those records.
I'm not criticizing, but there is a reason I won't buy a used bike as my primary ride.
Old Nov 18, 2015 | 10:12 AM
14GuineaPig's Avatar
14GuineaPig
Posts about brake failure is why I took my bike to the dealer for the brake fluid service. This is the first bike I've had with ABS brakes. As far as I know the dealer uses the Digital Tech to active the ABS system when flushing the brake fluid, something I can't do. I also have ESP so I wanted to document that the recommended brake service was done if I have any problems in the future.
Old Nov 20, 2015 | 09:26 PM
majorbrian's Avatar
majorbrian
I had this happen last year and had to wait a few weeks to get a new ABS module. This was not an inexpensive job.
Old Nov 21, 2015 | 06:53 PM
btsom's Avatar
btsom
Why doesn't this happen with cars? Few get periodic brake fluid replacement yet I have NEVER heard of hydraulic lock on a car. This suggests that the Harley ABS controller is in need of a redesign. The only possible failure mode should be a return to non ABS brakes, NOT a lock out resulting no brake.
Old Nov 22, 2015 | 12:26 AM
OwnerOfHarriet's Avatar
OwnerOfHarriet
How you decide it was it was hydraulic lock?
Old Nov 22, 2015 | 10:46 AM
btsom's Avatar
btsom
Read the OP, the front lever wouldn't move until he made a "leak" at the connection going into the ABS module.
Old Nov 22, 2015 | 02:38 PM
motolocopat's Avatar
motolocopat
I suggest that you buy the new $48 part that is needed not the used ebay part your considering looking for.
I suggest that you install the new part and flush the entire system, install new pads and bleed it.
I suggest you don't waste your time writing to the NHTSB and waste your time and theirs about a problem that you are likely responsible for since you don't know what the maintenance was prior to purchasing your 8 year old motorcycle.
I suggest that next time you buy a used motorcycle that you perform a full maintenance on it.. if you would have done that here you probably wouldn't be having the problem AND it would actually be time to do it again.
