Is this normal?
Old Nov 21, 2015 | 11:43 AM
steelerdude1's Avatar
steelerdude1
Default Is this normal?
This clanking noise just started, it wasn't there before. Just wanted to get opinions before I take it in.
Old Nov 21, 2015 | 12:19 PM
ZenGlide's Avatar
ZenGlide
What are you doing as you're rolling it back and forth? Are you applying brakes, letting out the clutch while in gear, etc? Need a little more description.
Old Nov 21, 2015 | 12:37 PM
harley0711's Avatar
harley0711
Stop running over your wifes wooden leg???
Jack it up , spin tire - rotate front end - get someone closer to the sound (safely) and try to isolate noise
Old Nov 21, 2015 | 12:49 PM
steelerdude1
Bike is in neutral, not pulling in the clutch, the clank comes from applying the front brakes.
Old Nov 21, 2015 | 01:04 PM
davidwruth's Avatar
davidwruth
Sounds like the Pistons in the caliper hitting the pads. Take the calipers off and check to see If something is loose or broken. Not that hard to pull them off to inspect them
Old Nov 21, 2015 | 01:15 PM
GTK's Avatar
GTK
Loud noise all right.
Old Nov 21, 2015 | 01:23 PM
azlou66's Avatar
azlou66
I would get the front end in the air and do a thorough check of all hardware.
Spin front wheel and apply brakes to try and duplicate the noise.
Isolating a noise like this is normally the most diffucult part of the fix.
Old Nov 21, 2015 | 02:03 PM
Jaystn62's Avatar
Jaystn62
2015? I'd be taking that thing in under warranty.
Old Nov 21, 2015 | 02:07 PM
ZenGlide's Avatar
ZenGlide
As others have mentioned, I would jack it up, spin the tire, and apply brakes. Having someone to help with the brake lever might allow you to get closer. I would listen and watch for any movement that doesn't look normal. I just went to the garage and tried to duplicate your actions. I get a slight clunk, but nothing that sounds quite as loud as yours. Of course, the camera audio can be deceiving.
If this were my bike and still under warranty, I would take it to the shop. They will probably tell you it's normal, but at least you have it documented if anything worse happens. IMO, any possible issues with brakes should be addressed with priority.
Old Nov 21, 2015 | 02:32 PM
bdtaylor1979's Avatar
bdtaylor1979
Could also be the forks sliding from hitting the brakes.
