Primary Gearing
Old Nov 24, 2015 | 05:21 PM
grbrown's Avatar
grbrown
No Keith, my bike is old enough to have a speedo driven by cable from the front wheel. No electrons are employed or disorientated by my changes!
Old Nov 24, 2015 | 07:02 PM
deadhawg's Avatar
deadhawg
True, but on newer bikes, changing the trans sprocket or pulley will affect the speedo and odo, by the same percentage as the tooth change.
Old Nov 25, 2015 | 04:34 AM
grbrown's Avatar
grbrown
Thumbs up
I realise that, but I have enough challenges with my build as it is, without being troubled by the speedo!
Old Nov 27, 2015 | 10:45 AM
motosman1's Avatar
motosman1
Originally Posted by Keithhu
Curious, and sort of off topic - does any of this mess with your speedo/odo?
Exactly why I'm going with primary gearing change. Inner primary stays in place, no added cost of belt and frt. pulley, no added cost of "speedo recal unit" and no additional labor. Doing engine mods that require clutch upgrade so I'm already there. Customer is going with a Baker OD-6, so in this case the inner primary IS comimg off. Primary ratio ends up at 1.54:1, final drive becomes 3.37:1 and the .86 OD takes it to 2.90:1.
Old Nov 27, 2015 | 11:55 AM
grbrown's Avatar
grbrown
I recommend you do a cost comparison of changing the rear drive ratio, against the primary! The cost of that new clutch with different size sprocket ain't cheap. My shorter belt arrived today, so hopefully my build will continue tomorrow, with both modified primary and rear drive ratios.
Jasper86
EVO
May 7, 2018 04:51 PM
RidemyEVO
EVO
Jun 26, 2012 11:56 AM
maddyv
Jul 18, 2011 12:05 PM
dognut
Oct 8, 2008 10:53 AM
tom73
Sep 16, 2008 07:32 PM
