Headlight aiming issue
Old Nov 26, 2015 | 07:45 PM
SiggerTX's Avatar
SiggerTX
Default Headlight aiming issue
Helping a friend install a dual bulb headlight in an 06 FLHT. This unit is a HD accessory meant for models with the 3 prong headlight, I have the same unit on mine. The issue is that I can't get it to adjust nearly high enough. I've got the screw in all the way and it is shining like 20' in front of the bike. Nothing has been altered suspension wise, and the adjuster does go down just fine (almost to the fender). Only thing I can figure is that he has the FM LED bulbs and maybe they are hitting something inside limiting the travel?
Old Nov 26, 2015 | 08:06 PM
mikelikesbikes's Avatar
mikelikesbikes
If you honesty think that is the case try something such as washer(s) to compensate. I have changed quite a few headlights and never had the problem so just shooting from the hip here.
Old Nov 27, 2015 | 06:55 AM
Shotgun's Avatar
Shotgun
I had the same issue on my '06 ultra cvo. I ended up shortening the adjusting screw which was hitting the housing.
Old Nov 27, 2015 | 07:28 AM
SafetyMan's Avatar
SafetyMan
Where are you located... I don't know where So Texas is.
VegasGeorge
Screamin Eagle CVO Models
Aug 11, 2018 12:13 AM
QC-RAIDERS-91
Apr 18, 2012 07:45 AM
scomike
Mar 13, 2011 06:12 PM
skullandcircle
Sep 15, 2007 03:31 AM
veniculum
Sep 8, 2006 12:18 AM
