Question about Tyre for GPS
Old Dec 8, 2015 | 09:11 AM
tringle's Avatar
tringle
Default Question about Tyre for GPS
I know quite a few of you are using Tyre to create your routes for your infotainment GPS. I'm using Basecamp with no problems, but I wanted to experiment with Tyre. The route is saved as a "TRF" route. Will the GPS recognize those files. I'm used to using gpx.
Thanks!
Old Dec 8, 2015 | 09:28 AM
grbrown's Avatar
grbrown
Tyre will routinely 'save' as a trf file, however if you use 'save as' you should be able to save as a gpx file. I have used Tyre for several years now, with TomTom gps units. You should be able to open gpx or trf files (and many other types as well) and save them to all those types, including gpx.
Later Garmin files are gdx and I haven't been able to use them yet.
Old Dec 8, 2015 | 10:11 AM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
+1 on the save as ......
I have Garmins, and the native format is gpx (Garmin GP eXchange files) I just did a "save as" to see if gdx was there, and it's not an option for Garmin. It's also not listed as an import option.
Old Dec 8, 2015 | 10:35 AM
grbrown's Avatar
grbrown
Red face
You're quite right, I should have written gdb, which are the ones I have here but can't open.
Old Dec 8, 2015 | 10:43 AM
shooter5074
Try this....http://science.opposingviews.com/use...uvi-16719.html
Instead of saving to the GPS after you load the gdb file, do an Export to a GPX file.
Worth a try
Old Dec 8, 2015 | 11:08 AM
grbrown's Avatar
grbrown
Thanks Shooter, but I use a TomTom and use Tyre, I don't have a Garmin or Basecamp. It's my bike club pal who has the latest model Garmin, but he won't retro-save to create a gpx, for the less fortunate amongst us!
Old Dec 8, 2015 | 11:43 AM
shooter5074
Must be a UK thing. I just bought a Nuvi 2689LMT for my car, and it still uses GPX.
Or
Maybe he's just a jerk
Old Dec 8, 2015 | 12:08 PM
grbrown's Avatar
grbrown
I suspect all Garmins can still use gpx, but he likes to have the very latest stuff. I just don't recall which model it is - one of the bike models, for use on his new KTM.
Old Dec 8, 2015 | 12:20 PM
Hausguy's Avatar
Hausguy
I believe the OP was referring to using his Infotainment (rushmore?) GPS. I'm also a Tyre user and there are many different "save as" options. Cheers.
Old Dec 9, 2015 | 04:37 AM
tringle's Avatar
tringle
Thanks for the replies. I'll just change the format. I was curious though to see if the infotainment gps excepted any other format. Thanks again.
