Another Truck lite Install
Old Dec 18, 2015 | 10:10 AM
BoonDock_Saint's Avatar
BoonDock_Saint
Default Another Truck lite Install
Finally, I dropped the $189.00 and had Eastern Performance ship out a truck-Lite phase 7. No issues with Eastern, it arrived when they said it would.
Removing the OEM head lamp is straight forward, right up until you break off one of the retaining ring tabs while cleaning it. So, out comes the JB weld to replace the shitty single spot weld holding the tab on. Upon assembly, I was surprised that it took 5 full turns of the vertical adjuster to get the light properly adjusted.
Doing research prior to the purchase, I read a number of complaints about cornering at night and the light not scattering enough to see very far into the corner. They were right. The best feature of the LED is also it’s Achilles heel. The light beam is very linear in that it cuts off abruptly to keep from scattering light everywhere. Going into a curve like a ramp, it tends to cut off 6-10 feet earlier than the old halogen. That’s not really the issue. The light cuts off so abruptly when you're leaned over, it looks pitch black just beyond the end of the light so it’s a bit unnerving at first. Fortunately on the FLH, you’ve got the passing lamps to compensate for this phenomenon. That and the fact that there aren't any curves in FL other than ramps, this won't be much of an issue.
On the FLH, you have to use Harley’s frenched trim ring to completely cover the light housing otherwise you have the last ź inch of the light assembly exposed beyond the stock trim ring. If I didn’t already have it, I wouldn’t have blown 50 bucks on it. Form follows function with me. That 50 could go toward moto lights. Besides, it really doesn’t look that bad.
Considering these issues, it’s still one of the best investments you’ll make for your bike. The increase in viewable area is incredible. What used to be a dimly lit road shoulder is now as bright as what’s in front of you giving you a lot more reaction time when something wanders toward the road. Properly adjusted, you can see 30+ feet further down the road more clearly and you’re not getting flashed from oncoming cars on a 2 Lane road. This is all before you hit the high beam. You may as well have a switch to turn on the sun! I put a beating on the high beam switch the first night….. the amount of light is so unbelievable you have to turn it off and on repeatedly just to grasp the enormity of it all! In my testing, I've found that when properly adjusted, you can ride on a divided 4 lane road with the high beam on and no one is flashing their brights at you. Don't do this on a two lane road, oncoming traffic will be flashing you from 50 yards. Besides, you're likely to burn someone's retina!
I"m going with the fuelMoto bulbs for the passing lamps. EDIT: after reading the reviews of these bulbs, I'm looking elsewhere. Ultimately, I'll problaby have to bight the bullet and buy the passing lamps.END EDIT. I won't drop another 200 on passing lamps just so they match because, quite frankly, when the bike is on the side stand, the headlight doesn't look that great when it's turned off and I don't see what it looks like when I'm riding it!
Happy Motoring!
Old Dec 18, 2015 | 10:22 AM
bigheadted's Avatar
bigheadted
I love lots of light on my bikes and did the Trucklight 7 a while back I love it and the cornering light is a non issue for me. I live in the Sierra foothills and ride twisty roads all the time. After a year I finally went with the passing lamps too and they were a massive improvement over my PIAA equipped ones. Another benefit is less heat and amp draw.
Old Dec 18, 2015 | 04:18 PM
Crimson's Avatar
Crimson
Yeah the passing lamps make a big difference in the volume of light to the sides. Without them I agree the beam is a bit narrow.. Overall I've had mine for about a year now and very happy with the improvement over stock and price!
Old Dec 18, 2015 | 04:43 PM
Robjr's Avatar
Robjr
On the FLH, you have to use Harley’s frenched trim ring to completely cover the light housing otherwise you have the last ¼ inch of the light assembly exposed beyond the stock trim ring. If I didn’t already have it, I wouldn’t have blown 50 bucks on it. Form follows function with me. That 50 could go toward moto lights. Besides, it really doesn’t look that bad.
I"m going with the fuelMoto bulbs for the passing lamps. I won't drop another 200 on passing lamps just so they match because, quite frankly, when the bike is on the side stand, the headlight doesn't look that great when it's turned off and I don't see what it looks like when I'm riding it!
Happy Motoring!
I absolutely love my phase 7 and matching passing lamps. Was well worth the money and I'm a bit of a nut for Another Truck lite Install-photo417.jpgAnother Truck lite Install-photo309.jpgAnother Truck lite Install-photo501.jpgeverything matching.
Old Dec 18, 2015 | 04:58 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
I went with the TLP7 trifecta and enjoy them.
Adjustment of the passing lamps is CRITICAL to balance out the show!
Old Dec 18, 2015 | 06:12 PM
fenwick's Avatar
fenwick
have to agree the passing lambs was hard to swallow [price wise] but glad I did it . with all three lights , its like driving my car. was very pleased with the results and I also like things to match
Old Dec 19, 2015 | 01:38 AM
PanHeadRich's Avatar
PanHeadRich
I love the look of these lights when off or on. I like that darker, more aggressive look. So for me, it's a win/win. I've installed these on 3 of my bikes over the past few years. All of which I've had to increase from 5.75" to 7" buckets. But well worth it the effort and expense IMO.
BTW, you can find them on eBay as low as $163 shipped. Here's just one example: http://www.ebay.com/itm/TRUCK-LITE-2...1TS-jw&vxp=mtr
Old Dec 19, 2015 | 04:01 AM
Jrsess's Avatar
Jrsess
I agree, the Phase 7 is an awesome light! JR
Old Dec 19, 2015 | 08:20 AM
OwnerOfHarriet's Avatar
OwnerOfHarriet
Happy Motoring!
I live in the mountains and have quite a different opinion regarding the TL. It spreads light across the whole road when cornering. Even with the passing lamps turned off. There are no dark spots.
The HD Daymaker is terrible for cutting off the light in the corners -- yes I have ridden with it.
The TL is a great light.
Old Dec 19, 2015 | 09:28 AM
VA_Larry's Avatar
VA_Larry
What part of FL? You I'm new to the Tampa area and always looking for people to ride with.
