Rinehart True Duals or Rinehart Slip-On
Old Dec 8, 2007 | 12:27 PM
MustBBrent's Avatar
MustBBrent
Default RE: Rinehart True Duals or Rinehart Slip-On
I asked this in a different thread, but this may be the place to ask it as well,
Does the crossover leave more low end torque than the true duals or can you not tell the difference? There is a bike at the local stealership that has a vance/hines header with Rinehart slip ons that sounds great, but it has no ***** in 5th at 65mph (it sounded like it was midway in the RPM as there is no TACH.) It's like the machine runs out of steam on the highway. So, I don't want to loose any more torque if you catch my drift.
Old Jul 31, 2010 | 03:38 PM
Ultra1946's Avatar
Ultra1946
Stage II
Default V & H Dresser Duals
Question:
Will changing to Dresser Duals and keeping stock mufflers reduce heat?
Will remapping be sufficient or is it necessary to install a management system?
Old Jul 31, 2010 | 03:48 PM
Mike's Avatar
Mike
I put Rinehart true duals on my bike this year and they are killer! They do have a different sound than the Rinehart slip ons with stock head pipes. Great sounding idle, but surprisingly quiet at cruise.
Old Jul 31, 2010 | 08:37 PM
Sallyman's Avatar
Sallyman
Originally Posted by Ultra1946
Question:
I would say yes, but not 100% sure as I believe most of the heat is dissapated through the head pipes but if I were to add head pipes I would trash the stock mufflers.
You only have to remap if you change the air cleaner, I believe a pipe/muffler change only don't require an ECM change or a fuel management system.
Old Aug 9, 2010 | 10:55 PM
vtwinhd59's Avatar
vtwinhd59
I have installed the Rinehart true duals on my 2010 Street Glide. Sound and performance is unbelievable. I'd highly recomend these pipes to anyone. Only issue is the pipe off of the rear cylinder runs right over top of oil cap and trans screw. Does anyone have a solution for checking/changing fluids with this setup? It's not a huge deal, but something to think about as I hate getting burned.
Old Aug 10, 2010 | 02:19 AM
Mike's Avatar
Mike
The true duals with the stepped headers will perform better than the straight 1 3/4" headers. When I pulled my y-pipe earlier this year for the fullsac conversion, I felt like I had lost a little off the low end. When I pulled that system off and went to Rinehart TDs, I hot it all back and more.
Old Feb 15, 2011 | 01:14 AM
dryheave's Avatar
dryheave
4th Gear
did you ever get a reply to your question about the second pipe going over your trans screw and cap?
camilo4x4
Jan 28, 2011 03:40 PM
Chrome Sweet Chrome
Aug 16, 2008 05:54 PM
Ohio HD Guy
Apr 30, 2008 01:42 PM
smathisen
Sep 21, 2007 01:32 PM
VicDawg
Exhaust System Topics
40
Sep 13, 2007 05:49 PM
