Transmission Problem?
Old Dec 30, 2015 | 09:03 AM
hardheaded's Avatar
hardheaded
i wouldn't think the pawl spring is broken at 5200 miles, but you never know. and yes the entire gear set has to be removed to get to it, along with the exhaust and primarys.
Old Dec 30, 2015 | 09:06 AM
Jackie Paper's Avatar
Jackie Paper
Did you recently replace the shift rod. Lot of aftermarket spherical bearing joints out there that are junk. Those joints need to be loose. Sloppy loose does not hurt. It's just part of the travel. When you realize the lever moves 2 1/2", whats a 1/64" more mean? However, a tight plastic bearing joint will never free up.
Old Dec 30, 2015 | 08:22 PM
ses's Avatar
ses
I have to agree with Ripsaw about cheap shift rod ends! Had the same issue after I changed mine, I would follow the advice about removing the shifter linkage at the transmission and see where it is binding.
Old Dec 31, 2015 | 09:11 AM
hardheaded's Avatar
hardheaded
yep, above two posts are good advice !
Old Dec 31, 2015 | 10:50 AM
dyna rider's Avatar
dyna rider
Default Shift Rod
A few months ago I replaced the rod end bearings, Heim joints, on my touring bike and went for about a 80 mile jaunt. I tightened the bolts on the shift rod too tight and there was no spring back and lots of clutch slippage. I stopped half way through the journey and loosened them up and everything was hunky-dory again. I did change the primary fluid shortly after this occurred. Checking to see if the shift arm is too tight should be your first move and then if it isn't fixed go into the trans.
Old Jan 2, 2016 | 06:32 PM
TangSooDoMan's Avatar
TangSooDoMan
Originally Posted by RIPSAW
Did you recently replace the shift rod. Lot of aftermarket spherical bearing joints out there that are junk. Those joint need to be loose. Sloppy loose does not hurt. It's just part of the travel. When you realize the lever moves 2 1/2", whats a 1/64" more mean? However, a tight plastic bearing joint will never free up.
That is what the problem was, the rear hiem joint on the shift arm.
Old Jan 2, 2016 | 06:42 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Got lucky on that one, big bucks for the shifter pawl replacement.
Old Jan 2, 2016 | 06:49 PM
Jackie Paper
Too cool..Thanks for getting back with what you found.
Yellow Glide
Mar 24, 2022 07:27 AM
BIGGINS88
May 15, 2013 09:12 AM
Magnum 61
Jun 11, 2010 06:29 AM
12Gauge
Mar 2, 2010 10:51 PM
