Transmission Problem?
Old Dec 29, 2015 | 09:17 PM
TangSooDoMan's Avatar
TangSooDoMan
Default Transmission Problem?
Went for a ride today and had a problem shifting. When I shifted from one gear to another, the shift lever didn't "spring back" if you know what I mean. This caused a problem when down shifting, when I went down, I would have to move the leaver back up with my toe or I couldn't shift down again. Anyone have any idea what could be wrong?
BTW, I have a 2010 Road King, 5200 miles, all fluids changed about 200 miles ago.
Old Dec 29, 2015 | 09:20 PM
lp's Avatar
lp
Could try greasing your shifter shaft.
Old Dec 29, 2015 | 09:37 PM
TangSooDoMan
Would "never seeze" be a good thing to use, or would regular grease be better?
Old Dec 29, 2015 | 09:43 PM
sn95bullitt's Avatar
sn95bullitt
Might need a new spring in the trans.
Old Dec 29, 2015 | 10:14 PM
TangSooDoMan
Is this spring INSIDE the transmission, and how hard is it to get to?
Old Dec 29, 2015 | 10:24 PM
Crimson's Avatar
Crimson
Perhaps the dirtiest thing ever unintentionally said on HDForums?
Old Dec 29, 2015 | 11:13 PM
Fishrrman's Avatar
Fishrrman
OP wrote:
"Is this spring INSIDE the transmission, and how hard is it to get to?"
I had a similar problem once.
It -was- the shifter spring, inside the transmission.
The spring itself is cheap, only a few dollars.
GETTING TO the spring is what's expensive.
I believe the entire guts of the transmission have to come out to access it.
Perhaps others in the forum can offer tips or tricks.
Old Dec 29, 2015 | 11:15 PM
johnnynitro's Avatar
johnnynitro
Prawl Spring ?
Old Dec 29, 2015 | 11:18 PM
sn95bullitt
If I remember correctly its right under the top cover. I've only rebuilt one trans.
Old Dec 30, 2015 | 08:49 AM
GTK's Avatar
GTK
Disconnect your shift linkage to rear trans shift arm and then you can determine if its a spring problem or binding at the front shifter shaft.
