Jagg vs Ultracool
Also have mine set up with braided hoses and AN type screw fittings.
It's night and day compared to the HD one a had installed.
I posted my install with photos of my Jagg 10 row cooler on this forum. Maybe a search will help you find it.
I have a stock 09 flhtcu w-96" motor that i installed wards cooling fans along with an ultracool oil cooler with dual elec cooling fans both at the same time working collectively together reduced oil temp 50+ deg f on hot 90+ deg HHH summer days.
I have had the wards fans & ultracool oil coller on the bike for 1 season/8,500 miles thus far with no issues with either of those cooling mods/units.
The Oil now running 50+ deg F cooler (motor also has to be running x-amount deg cooler too) on hot summer days resulted in:
* reduced valvetrain / lifter noise.
* stopped detonating (pinging) when using HD's rec 91 octane fuel for the stock 9.2 compression 96" motor my bike has.
* post installing the 2 cooling mods that reduced oil temp 50+ deg hot oil pressure was increased from 8-10psi @ idle & 32-35psi @ cruise without the 2 cooling mod to now 18-20psi @ idle & 45-48psi @ cruise with the oil & motor hot in 90+ deg F outside summer HHH heat with the 2 cooling mods & spectro 20w-50 oil specifically engineered & formulated for lrg air cooled HD v-twins.
Hot oil pressure ran approx 5psi or so lower with a bit more valvetrain noise in same cond in my bikes motor when it had HD's Syn3 & M1 v-twin in it both being syn 20w-50 bike oil then the spectro 20w-50 oil for hd's did in my bike in same cond & heat.
* hot starts post fueling are easier/faster due to motor, starter & battery being a bit cooler.
* bit less heat is coming off motor so little more comfy to ride in summer temps.
* motor now retains noticeably more pwr/trq & crisper throttle response on hot days due to engine/oil/intake/throttle body etc all running a bit cooler.
Scott
" It's night and day compared to the HD one a had installed "
Well not really & heres why i say that when talking std oil coolers.
Thats because having no cooling fan-s on a std type oil cooler on a motorcycle renders the oil cooler almost useless when its needed most like for example when " sitting still at stoplights and or when in slow mowing traffic " .
Thats because at stoplights & in slow moving traffic there little to no air moving thru the oil cooler in those cond resulting in little to no effective cooling of the oil & or motor again " when its needed most sitting at stoplights or in slow moving traffic " where it's crucial to have elec cooling fans on a motorcycle oil cooler esp with a lrg disp air cooled HD V-twin.
I have wards fans & ultracool oil cooler with dual elec cooling fans which working together reduced oil temp 50+ deg on hot summer days that resulted in 5-6 great improvements in perf & or ride comfort right off the bat .
If i turn off the cooling fans on the oil cooler the oil temp rises quickly when at stop lights & or when in slow moving traffic and when i turn the cooling fans back on for the oil cooler in traffic & at stop lights the oil temp go's back down again because there is ample good / cool airflow thru the oil cooler to effectively cool the oil.
Reducing oil temp 50+ deg F on hot summer days resulting in the multiple improvements in engine perf & comfort i already stated above in this thread is what i call a " DAY & NIGHT DIFFERENCE " in oil cooler perf! / LOL!!!
Scott
It is for that reason alone I would consider the Ultra Lmited.
If I could swing it $$$S wise I would buy one.
I have an Oil bud cooler on. It is the biggest O C that is made and the most expensive.
They guarantee a 35 drop in temps. It does that but just shy of $600 bux is a lot of green.
Does what it's supposed to. No leaks. I put a mood glow light on the dash that changes colors softly as opposed to a bright led light telling me it's working when it goes on. No problems.
So at and with that I am stuck using a PC-V for a tuner.
