Price for cam install
What'd it get you?
Were you cammed with the 96 then or?
What cams now and tuner ya runnin w/that 107?
I have a 2012 SG. I'm going to have my indy shop install the Andrews 57h cam.
My goal is to compare the cost of me providing the parts vs. my indy shop providing the parts.
When I go to the fuel moto website for example, they sell a cam install kit for $59.95. So, other than the actual cams, what else is necessary?
Thanks much!
Couldn't keep up with my buddy's 2001 ultra with a 95" big bore & cams. His son-in-law's Screamin' Eagle Ultra would smoke both of us.
Added FM 107 with Woods 555 cams, 2-1-2 pipe & Power Vision and those guys couldn't keep up. Pulled like a freight train in any gear and never disappointed on fuel economy (42-45 mpg on the highway).
I now have a 2013 FLHTK with the stock 103. It's better than the 96" but not much. After enjoying the performance of the 107 so much, I don't think I'd consider doing cams without punching it out to a 107.
Next year same dang thing, I supplied and he installed, all of a sudden it was two hours.
Any head work?
24018-10 KIT-CAM BEARING ASY,TC96 1 $17.22
39969-06 CHAIN TENSIONER, SECONDARY 1 $32.02
18404-08 KIT, TAPERED ADJUSTABLE PUSHRODS 1 $152.96
17045-99D CAM SERVICE GASKET KIT, 1450/1550/1680 1 $90.37
25282-11 KIT-CAM PLATE SUPRT,W/HI-VOL OILPUMP 1 $371.54
39968-06 CHAIN TENSIONER, PRIMARY 1 $32.02
94076-09 CAM LOCKING TOOL, ROLLER CHAIN 1 $34.51
Harley Davidson TC 96 103 110 Dyna Twin Inner Cam Bearing Installer Puller $100
S S 583 CHAIN DRIVE CAMS EASY START CAMSHAFTS 07-UP TWIN CAM HARLEY CAMS 49-8452 $318.45
33-5350 S&S High Performance Hydraulic Tappet Set for Harley Davidson
$99.95
Edit, I did the work myself. Easy stuff
Thanks much!
Big difference there.
Don't know why you went from a 107 to a 103 unless you just decided that you didn't want to swap over the motor components and performance items, I'm guessing?
Yeah, there is not much difference between an older 103(13) and a older 96 with the cams they used in them.
Now there is a significant difference between the 13's and the 14's though.
Using bigger cams.
Some on this site with the pre-14's have even installed the 14's cam's in their pre-14 motors for a bump in HP/TQ.
