Aux Light Ground
Old Jan 14, 2016 | 07:19 PM
nicmartim's Avatar
nicmartim
Question Aux Light Ground
At the end of the last riding season I noticed my left Aux light would turn off randomly while cruising. Being winter and all I finally got around to checking out why and found the ground inside the light housing snapped off. It appears as though this has happened before and fixed by the previous owner with LOTS of solder. Well this time when it broke it broke much further down now all I have is a small portion of the nub that is riveted to the housing. I would guess it's not enough to re-solder to and too small to try and butt connect the ground to. What is the best idea here? I have half a mind to run a wire out of the housing and back into the nacelle, but that would be a PITA.
Old Jan 14, 2016 | 10:02 PM
madsonp's Avatar
madsonp
Can't you drill out the rivet and install a new rivet and a connector to hook the ground to ?
Old Jan 15, 2016 | 06:57 AM
im's Avatar
im
Are the aux lamps stock?
Unusual for a ground to have a problem twice unless there was a large draw on the line or the wire was rubbing due to incorrect installation.
If the forks are properly grounded to the frame, any ground point would be sufficient.
I would review the draw first.
Nlstreetbobber
Sep 2, 2021 01:55 PM
Bluraven
Oct 13, 2017 01:51 PM
krakenmoto
Apr 6, 2017 03:21 PM
sixty4nhalf
Mar 1, 2013 11:03 PM
SURFOR Chop
Nov 10, 2010 01:29 PM
