Reflex Braking System, do you like it?
Old Jan 29, 2016 | 06:25 AM
  #91
fatboy slim's Avatar
fatboy slim
Originally Posted by End Loser
I knew this would come back on me as being the issue.
I have been riding motorcycles of one kind or another since I was 7, raced motocross for many years (but not any longer). I know how to modulate brakes. The linked brakes on this bike are too sensitive for my liking and I will find a way to change it. If that means taking it off, then that's what it will be.
Anyone know of a way to disable the linked system?
Had my dealer look into this as I was interested in a new RK. You need to change the brake parts, and the ECU to get round the can bus errors etc generated by changing the braking parts, was about Ł5000 all in I think. I've done the whole linked brake thing on another bike, never again.
Old Jan 29, 2016 | 07:21 AM
  #92
grbrown's Avatar
grbrown
Exclamation
Originally Posted by cwsharp
Actually, I am suffering from an uneven application of the brakes when using both front and rear brakes at less than 25 MPH. The brakes also tend to grab in this same situation but that may just be because I can't get use to their sensitivity.
I stand by my earlier remarks. Also practice makes perfect. If as you claim the brakes are very sensitive then ride it a lot more and get used to it!
I owned a high performance car some years ago. Despite having two brake servos the foot brake required huge pressure, so much that I had to adjust the seat so I could apply it. Not surprisingly it made driving any other car difficult, because I got tuned into applying over 100 pounds of pedal pressure! You need to tune your fingers to adjust to your feather-weight brakes.
Old Jan 29, 2016 | 07:39 AM
  #93
End Loser's Avatar
End Loser
Changing other components besides the brakes is not an acceptable answer to me. Thank you for giving your opinion. Now, let us folks who don't like the system figure out a way to change it. Just because you think it's fine and you think we should get used to it does not hinder my desire to change it. Just like you didn't care for the wobble, or some other guy didn't like the front forks, you guys set out and found a way to make a change and you did it. That is all I'm doing here too.
So to recap, there ARE ways to make changes to the linked braking system.
1. Reprogram the BCM
2. Replace linked system with non-linked system
Old Jan 29, 2016 | 08:55 AM
  #94
batman.'s Avatar
batman.
You forgot option 3. Go get a different bike with out linked brakes then. Cheaper all the way around.
Batman
Old Jan 29, 2016 | 02:15 PM
  #95
cwsharp's Avatar
cwsharp
well... based upon the bikes you post as yours, you aren't dealing with the same thing as I am. I promise you after 50 years of riding hundreds of thousands of mile your approach to this issue is insulting.
Old Jan 29, 2016 | 04:21 PM
  #96
grbrown's Avatar
grbrown
You're not alone in riding that long. Best of luck in your quest.
Old Jan 29, 2016 | 05:22 PM
  #97
Schex's Avatar
Schex
Originally Posted by kingmoochr
End Loser
I am having to assume at this point, with your experience, that your gripe comes with trail braking only. I bet most of the people here don't trail brake, or even know what it is. That is the only time I could imagine the system being an annoyance.
I come from sports bikes, where 90% of your braking is done with the front brake. I use the rear more on the King. Due to the weight bias there's increase effectiveness with the rear compares to sportier bikes. Still, I apply the front first and then the rear if I feel I need it. However, these are always STOPPING/SLOWING situations in everyday riding.
Trail braking is only used when trying to maximize corner speed, specifically entry speed. It is braking used in performance riding. I could see it being real bad if I was coming in hot, and wanted to scrub speed with the rear, and the bike applied the front for me. I would be real curious to see someone out testing a touring bike on a track, trying to trail brake at the near limit, seeing if they could get the linked system and ABS to fight each other to keep the front from washing out.
Obviously this doesn't apply to most riders, which I think is where the confused/negative input is coming from. So, do you not like the dive while you're braking in the twisties, or is there another specific instance where it causes you unpleasantries?
As for disabling it, if it uses the same plumbing as the ABS system and is totally computer controlled, I doubt there is an easy option. Maybe you can just swap the brains from a linked and non-linked bike?
I rented a '15 RG for a weekend last year, the first day, we (the OL and I) rode with a large group and at most people's normal pace, I didn't have any complaints about the braking or suspension.
The next day, the OL and I went out by ourselves and I hit some twisties to have some fun and rode the way we normally ride, well, both the suspension and braking department definitely lost some points.
I experienced exactly what kingmoocher stated, I trail brake when hauling azz if coming in a little hot, the damn computer would apply the front brake progressively harder the longer I tried to trail brake and not upset the bike, I always ended up over braking as it seemed to have a small delay when I first applied the brakes and when letting off.
I need the brakes to work exactly when I want and hard as I want, fronts or rear, the computers manipulation just screws me up.
It was hard to be smooth with the trail braking.
Maybe something I could get used to, maybe not.
Bottom line is it was aggravating to me,
I'd bet most people never ride hard enough for it to affect their riding style.
Old Jan 29, 2016 | 06:38 PM
  #98
btsom's Avatar
btsom
Originally Posted by not a sock
I'm gonna agree as well.
Apparently the OP wants the majority to agree with him that the problem is with the system and not him.
Some folk are like this; they'll ask the same question until someone tells them what they want to hear.
Or he gets a simple answer to a simple question: Can they be disabled? A yes or no would be appropriate. IF pulling the ABS fuse also disables the linked brakes, do it and take a test ride, see how the brakes and suspension act. Pulling the fuse as an experiment is not permanent and would allow for a more informed decision as to the next step.
No one has mentioned the hydraulic lock malfunction becoming more common in Harley ABS units. I find the idea of totally losing a brake to be terrifying, but that's just me.
Old Feb 2, 2016 | 12:48 PM
  #99
scottt's Avatar
scottt
Batman
This is the only sensible answer to the OP's desire to eliminate the linked brakes.
Personally I love them, especially after I upgraded my front suspension. My opinion does not matter.
Trade in the bike for one without linked brakes. Simple
Old Feb 2, 2016 | 07:08 PM
  #100
End Loser's Avatar
End Loser
Trading the bike in is not an option, at least at this point because of how new it is. I actually really like it otherwise, and I am trying to get used to them.
