Wiring help please...
Old Jan 18, 2016 | 11:58 AM
skydude426's Avatar
skydude426
Mkguitar and vernal are right. Your to the point that you need wiring diagrams and a multi meter.
Old Jan 18, 2016 | 04:04 PM
im's Avatar
im
So you have a 1996 Harley-Davidson Electra Glide Classic.
I believe that model is the M & M fuel injection.
From a distance i think you have more than one problem but all are probably simple.
If it is fuel injection then it is M & M fuel injection.
#1 I tell everyone that will listen to look at the crank position sensor CONNECTOR.
The connector is located on throttle side, behind painted side cover, under seat, near saddle bag. The connector is black, pencil thick and is a push and turn connector. Real close to ECM. If loose it will shut-off over bumps. If you worked near rear shock then tie wrap holding it was probably cut or connector moved.
#2 You probably have a burned fuse. Fused can be checked visually after removal with a good flashlight if you have no digital multi-meter.
Old Jan 18, 2016 | 11:10 PM
Vernal's Avatar
Vernal
I don't have schematics for the 96 but if they are wired like the 04 then by the original post his Headlamp, Lights and Accessory fuse may be blown. Hopefully he can just replace fuses and be done, if not a meter will come in very handy.
evotrike
Electrical/Lighting/Alarm
Apr 12, 2019 05:46 PM
Bowhunter8607
Jun 7, 2015 06:44 PM
Odelay
Mar 8, 2013 02:07 PM
Odelay
Mar 5, 2013 03:06 PM
matt1234
Jun 23, 2012 05:14 AM
