Heritage stock bars for rkc
Old Jan 18, 2016 | 06:22 AM
Rimfire03581's Avatar
Rimfire03581
Default Heritage stock bars for rkc
I might have messed up but does anyone know if a hd part number 56623-99 stock softail bar will work with factory 07 cables. After I ordered I see the correct bar is the tall boy for my ride but hear of people complaining about the wrist angle. I Did my research off of the heritage style bar pn 56902-08 for 08 and newer, they both had the same measurements, but the tall boy is different. Just want to make sure I didn't screw up. I also ordered the reproduction grips from hd as well.
Old Jan 18, 2016 | 12:13 PM
bigheadted's Avatar
bigheadted
Once I tried Heritage bars I quit looking. They just fit good.
Old Jan 18, 2016 | 07:56 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
I picked up a set of bsrs from a heritage softail at a swap meet and mounted them on my 04 rkc with no wiring modifications, no cable issues, and only a little bending of the brake hardline.
Old Jan 19, 2016 | 09:34 AM
bikerlaw's Avatar
bikerlaw
Yeah, they will work. You just need to cut free the wiring from all its ties, and free up all the slack. But there is enough slack that they will work with no cutting or splicing. You will probablly need to gently bend the front brake line, but that's pretty much all there is too it with those bars. Your clutch cable will have a tighter bend than it currently does so I suggest buying cable lube and while the cable is off the lever and pointed at the ceiling, use that opportunity to lube up the cable.
tinmarine
Jul 30, 2013 03:01 PM
"Big E"
May 23, 2011 12:34 PM
pargenz
Jan 19, 2011 07:53 PM
pennstater
May 30, 2010 12:21 AM
philthy51
Mar 6, 2009 07:41 AM
