Throttle Position Question
Old May 12, 2007 | 11:19 PM
ezlife's Avatar
ezlife
Default Throttle Position Question
Installed the PCIII from Jamie premapped for my setup on a '07 RK Classic and bike runs great. However, been read'in alot about setting the throttle position after installing the PCIII. I understand the position and associated rpm range is whats used when tweaking the a/f ratios, so the map has to accurately know 0 throttle and full throttle to factor percent of throttle accordingly, makes sense. I think I got it, right? So do I need to plug in my laptop to the PCIII on the bike and open installed map and set the TP? I see there is a "set throttle position" selection in the tools menu in the software. What's the procedure?
Lead me out of the dark please...
As always, thanks bros!
Old May 12, 2007 | 11:29 PM
gdbro4's Avatar
gdbro4
Default RE: Throttle Position Question
Check out the information atPower Commanderssight. It gives you all the instructions for everything. It's easy to do. Good luck.http://www.powercommander.com/powerc...downloads.aspx
Old May 12, 2007 | 11:30 PM
ezlife's Avatar
ezlife
No reply needed.
Taterdog answered in another post, thanks bro for link!
Old May 12, 2007 | 11:34 PM
Taterdog's Avatar
Taterdog
Be sure you read the instructions closely, i.e. watch the tutoria closely. The bike has to be warmed up and running to set the 0% position. They say you don't have to set the 100% position, but if you do they say you blip the throttle to 100% so that they rpm only goes to 2000 to 3000. But, they also say the 100% can be set by plugging in the battery while the bike is running, then turning off the bike (I assume you leave the ignition on) and set the 100% position without the motor running.
It's all in the tutorial. Good luck.
LarryLives
Jun 25, 2011 06:09 AM
roadrider
Mar 9, 2008 04:59 PM
Tommy Meisel
Jul 23, 2007 11:03 PM
forestfarm
Jun 4, 2007 11:43 PM
ezlife
May 16, 2007 12:39 AM
