internal throttle?
Old Feb 21, 2016 | 07:44 PM
heiner921's Avatar
heiner921
Default internal throttle?
looking to do an internal throttle on my 06 road king. any one done this before? my bike has dual throttle cables and to my knowledge I can get ride of the return one. anyone one that has done this mod please PM me as I have a few questions for you.
thanks in advance.
Old Feb 21, 2016 | 07:55 PM
kingmoochr's Avatar
kingmoochr
I've removed the return cable but no internal throttle. The return cable is a DOT mandate, there are probably hundreds of thousands of muscle cars in the world with no return cable/linkage. It isn't mandatory for proper operation.
Old Feb 21, 2016 | 08:12 PM
mkguitar's Avatar
mkguitar
early models had an internal to the bars .060 steel wire in a cable housing which PUSHED the throttle open.
I have this on my '53 ( as is stock), the left side has a similar wire to push the timing housing to advance/retard spark.
if you look at older parts catalogs, you'll see how this works..the Vtwin catalog has repros of all that old stuff.
mike
Old Feb 22, 2016 | 02:18 PM
heiner921's Avatar
heiner921
has anyone done this on newer bikes? i know old bikes in the 70s had the internal throttle and touring bikes newer than 2008 have throttle by wire but has anyone with say a 98-07 touring add change to the internal throttle? im building a road king and im trying to clean everything yup. already have wires ran internally but id like to run my cable inside as well if i can. what brand did you go with... and do you have a link to the internal throttle that you used?
Old Feb 22, 2016 | 06:54 PM
btsom's Avatar
btsom
If your bike won't go, that's bad. If your bike won't stop, that's worse. Are you sure you really want to get rid of the redundant safety feature? I guess there is always the kill switch if you think of it in time.
Barrysg
Sep 1, 2018 02:07 PM
zachpeed
Mar 2, 2014 10:32 PM
PanGuy
Panhead
Feb 1, 2014 09:15 AM
jimmything
Jul 9, 2009 08:35 PM
christian0632
Mar 21, 2008 01:38 PM
