Been cleaning my ride up since I finished my stereo and found the speed nuts I used to replace the factory dzus mounts have deteriorated...to the point they crumbled while putting them back in. Glad I saved the stock hardware. I've had them speed nuts for about 2 years.
Wondering if anyone has come up with a way to box around the back of the factory setup to stop the screwdriver popping the pin trick or better speed nuts...
aside from popping the pin with a screwdriver, the other danger is the pin vibrating out ( i've had this happen to me, new bike, washboard road).
I use speed nuts from crown bolt- like at home depot...cost only a few bucks and they have been on over 5 years on my 09...the set on my '95 were on over 10 years...and probably still there.
mike
Just ordered the same kit, hopefully it's better than what I had. Just found it odd how brittle the speed nuts I had were..
I like them. The **** are easy to grip and sit flush enough against the bag. Use your OEM larger flat washer between the rubber grommet on the bags and the small lock washer.
I now run 1 dzus, and 1 allen head per bag, you can build a set just like above with an allen head, minus the finger bolts for about 5 bucks at Lowes.
This is exactly the config I use on my Road Glide and my wife's Road King. This works great at securing the bags but also acts as a deterrent to opportunity theft particularly with the non-lockable leather covered bags on my wife's bike.
