Performance Machine Tech front end install HELP!!??
Old Feb 27, 2016 | 04:04 PM
REELROADKING's Avatar
REELROADKING
1st Gear
Default Performance Machine Tech front end install HELP!!??
I am installing the Performance Machine Tech front end on my 2015 Ultra Limited and having a few issues wondering if anyone can help? When I tighten the front axle down to 55 ft lbs like they call for the legs are to tight for my LH caliper to fit on and the right hand axle cover will not stay on because the axle has pulled to far into the RH leg? Has anyone ever installed this front end and had these issues?
Old Feb 27, 2016 | 06:28 PM
Robjr's Avatar
Robjr
I'm not sure on a 15 model, my 05 I had to center it before tighten it down. I had a problem with my brake binding and pulling to one side. I was told to check alignment and that fixed it.
Old Feb 27, 2016 | 08:48 PM
REELROADKING
1st Gear
Center the wheel I assume you mean?
Old Feb 27, 2016 | 08:53 PM
Robjr's Avatar
Robjr
I had to center the axle on mine, apparently you can pull the axle into far causing the wheel to shift to one side.
Old Feb 27, 2016 | 09:05 PM
Robjr's Avatar
Robjr
Here's how to align.
Performance Machine Tech front end install HELP!!??-photo717.jpgPerformance Machine Tech front end install HELP!!??-photo71.jpgPerformance Machine Tech front end install HELP!!??-photo804.jpg
Seven71ne
Aug 7, 2014 11:21 AM
rideflhr
Mar 20, 2014 06:15 PM
jr50rider
Aug 16, 2012 07:07 AM
fxdx-fly-by
Mar 11, 2011 06:13 PM
bowhnter7
Dec 31, 2007 07:23 AM
