Machinist Help?
Old Aug 3, 2012 | 10:04 AM
jr50rider's Avatar
jr50rider
Default Machinist Help?
looking for help with machining an axle to fit my bike? I need my front axle turned down from 1" to 3/4" to fit an older style wheel with Timken bearings onto my 00 Glide.
Any help would be appreciated.
Thanks.
Old Aug 3, 2012 | 11:16 AM
Lakerat's Avatar
Lakerat
Where are you located?
Old Aug 3, 2012 | 11:35 AM
Leftcoaster's Avatar
Leftcoaster
Might be easier to buy the smaller diameter axle and machine new spacers.
Old Aug 3, 2012 | 12:16 PM
jr50rider's Avatar
jr50rider
located in mass on the rhode island line. i was thinking about buying an older style 3/4" axle from a touring bike, but the right lower fork leg axle hole diameter is smaller than the 1-1/8" diamter off my fork leg. not sure i can get a spacer to fit in the lower leg (safely). i ordered new 3/4" axle spacers already to center the wheel.
Old Aug 3, 2012 | 03:16 PM
Roadie09's Avatar
Roadie09
I attempted to modify one of the 25mm axles (a different project I was brain storming on) and since the axle was hollow it would not work for what I wanted to do. Is the 1" axle rifle bored (hollow)? If it is, it will become too weak for use if you turn it down to 3/4". If the axle is solid, it could be done as long as you do not introduce any stress risers that will generate cracks later.
Old Aug 3, 2012 | 03:24 PM
jr50rider's Avatar
jr50rider
The factory axle i have that i am hoping to have turned down, is 1" solid steel. the research i have done to date looks like the 99 and previous baggers had a 3/4" axle, same length, etc. although the ends in which fit in the older forks is a smaller diameter than my style forks, so that isn't really an option.
Old Aug 3, 2012 | 05:19 PM
Pelonz's Avatar
Pelonz
Older style fork legs might be easier way to go
Old Aug 3, 2012 | 07:05 PM
Flintshooter54's Avatar
Flintshooter54
Is it hardened or can a file cut it? Don't know if a axle is hardened or machinable.
Just checking.
Old Aug 3, 2012 | 07:31 PM
1flhtk4me's Avatar
1flhtk4me
It's probly just a low carbon steel.
Old Aug 3, 2012 | 08:26 PM
hawg50's Avatar
hawg50
if its a cast wheel you can open up the center of the wheel by machining part of the center out and use a 1 inch bearing and spacer,the outside diameter is the same as a 3/4 inch bearing.i have an older sportster cast lightningstar wheel on the rear of my 2006 ultra.if you want,you can pm me,i will give you my phone number.i might can explain it better.
