Tour Pack Wiring Harness.....Help?
Old Feb 29, 2016 | 05:21 PM
lpj21112's Avatar
lpj21112
Default Tour Pack Wiring Harness.....Help?
Hi, I'm installing a ultra classic king tour pack on my 07 FLHX. I picked it up at a swap meet and my local dealer told me that they don't have a wiring harness because most tour packs that are made for an FLHX doesn't have lights?????
Anyway, I installed a splitter to the harness under the seat.....I've tested the connection and figured out which pin in L and R Turn Signals, Brakes, Running Lights, etc.
The plug inside the tour pack only has 3 pins......the ground, the rear running lights and the side running lights......I've tested the lights and they all work but I don't want to wire the tour pack to just have running lights, I would at least like to have brake lights, turn signals on the back would be a bonus.....not sure how to go about it, I thought of splicing the turn signal but do I have to do it at the light individually because I think if I wire it direct to the harness that it would flash both lights looking like my hazards are on.....I can send pics upon request if my description doesn't make sense.....lol.....thank you in advance.
Old Feb 29, 2016 | 05:28 PM
mkguitar's Avatar
mkguitar
the colour code is
black ground
blue run
red/yel for brake
violet and brown are the turn signals
so that requires a 5 wire set up
I think what you have is side running lights and run/brake rear light on your T/P with the 3 wire set up ( which is stock/standard for some if not all years- it is for 2009 which is what I have a manual for)
you should have a dual filament rear light bulb.
I could imagine using the run/turn/brake module to get turn signals up top...or ... adapting a streetglide module to use your 2 tourpak rear lights as run/turn/brake
mike
Old Feb 29, 2016 | 06:26 PM
Vernal's Avatar
Vernal
Is this is what you are looking for?
http://www.harley-davidson.com/store...1-69200042a--1
http://www.boardtrackerharleyonline....-kit-69200042a
Old Feb 29, 2016 | 07:31 PM
lpj21112's Avatar
lpj21112
Default Thank you
Thank you for your help.
Originally Posted by mkguitar
the colour code is
black ground
blue run
red/yel for brake
mike
Old Feb 29, 2016 | 07:36 PM
lpj21112's Avatar
lpj21112
Default Thank you!
Thank you for the links.....I believe the service desk looked up that wiring harness and they told me it wouldn't work on my street glide, I followed your link to the Harley store and when I check for my bike (07 FLHX) it was not listed
I appreciate your help!!!!!
Old Feb 29, 2016 | 07:43 PM
mkguitar's Avatar
mkguitar
anything "tourpak" won;t be listed as compatible with your streetglide- as far as the computer is concerned...the streetglide won;t ever have a tourpak...so you have to fill in the blanks yourself.
that kit looks like the solution
Mike
Old Feb 29, 2016 | 07:44 PM
Mirnldi@gmail.com's Avatar
Mirnldi@gmail.com
The fitment chart in the link says it doesnt fit the street glide because it didnt come with a tour pak. The part in the link is what you will need for run turn for the tour pak. It will work for your application. Sorry Mk we must have been typing simultaneously
Old Feb 29, 2016 | 08:28 PM
Vernal's Avatar
Vernal
Looking at Ronnie's I wonder if there is a connector?
http://www.harley-davidson.com/en_US...ts/-J05081.pdf
http://partsfinder.onlinemicrofiche....ARNESS%20-%203
toyz2
Screamin Eagle CVO Models
Jul 19, 2013 06:55 AM
neonhomer
Jun 26, 2010 09:57 PM
Eric in chicago
Jun 15, 2010 08:28 PM
Bluerose
Feb 7, 2008 04:21 PM
toyking23
20
Apr 24, 2007 10:34 AM
