Progressive Suspension Setup
Below is the setup. I am looking to install it within the month:
Progressive Suspension 31-2500 Mono-Tube Fork Cartridge Kit
Progressive Suspension 444-4061B Black 12" Standard Big Mile Riders Rear Suspension Shock
Hoping this setup is be good.
http://www.progressivesuspension.com...4/touring-link
I have their 940's on the rear and the mono's on the front.
Pretty content with both.
Make sure you get the sag set right on the rears.
If you don't know anybody that can help you or don't want to experiment you can always get progressive to do it at a rally.
They are good folks to do deal with!!
With the help of a lot of people here, I decided the best solution for my wallet was Progressive 444s and Monotubes, and a Bagger Brace. I didn't like the design of Progressive's solution, and I felt the Bagger Brace looked just as effective as the Tour Track for a lower price.
I've installed the 444s and that improvement alone made an very noticable improvement in handling. I suspect those rear air shocks were toast, which accounts for how much improvement I got from the 444s. The deficiencies up front are now very obvious though, and the next step (which I'm undertaking now) is the install the Monotubes. There's a good thread underway about what it takes to install them. It's in the Touring forum and it's titled "Time Required to Remove & Replace Fork Tubes". https://www.hdforums.com/forum/touri...ork-tubes.html
If you decide to go with the Bagger Brace or the True Track, I strongly suggest you check the straightness of the cross member first. If it's bent (like mine is, and like I suspect most are) you'll need to straight it. For that I suggest you buy the True-Track "X-Member Tool" for $50. http://true-track.com/tt_products.html. I don't know about the True-Track, but you can not install the Bagger Brace unless your cross member is STRAIGHT.
EDIT: I'll sell you my X-Member Tool at a discount when I'm done with it in a week or so, if you're interested!
Having said that i want to progressively [no pun intended] add these modifications to determine what was the issues in the turns. So the suspension rear and front, with the idea that the True Track might be needed next. That looks like an easy add if i need to. I know some guys that have the 444s suppose to be adjustable on the fly but from what i've heard not so simple to adjust with a simple twist.
Is the progressive touring link basically the same as teh true track? I have people i know that went with true track so i'll keep that product.
Someone asked what riding i was doing. I do about 90% solo riding. This typically happens during long sweeping at about 75-80MPH.
