4 point Docking System
Old Mar 8, 2016 | 01:55 PM
chase.hollowell's Avatar
chase.hollowell
Default 4 point Docking System
I just bought a 2012 SG couple weeks ago. So I bought the 4 point docking system and I went to install it last night. When I took the Bags off and looked in the 2 holes thats didnt have bolts in them previously, they were rusty. I put my lock tight on my bolts tried to thread them in, Nothing. I took everything back off, took just a bolt and put it in there and had a hellacious time trying to get the bolt to thread (no it was not cross threaded) so I finally get them all in part way, and they have a 5/32 hex bit head and they get rounded out half way installed,
Should I try to go get better bolts?
Maybe something with like a torq head?
Ideas/suggestions please.
Old Mar 8, 2016 | 02:22 PM
Frank the Real Biker's Avatar
If you're sure about the size and thread, I'd suggest running a tap through it to clean out the threads. Forcing a bolt in there could result in ruining the threads. If you don't have access to a tap you might contact O'Reilly Auto Parts. They "rent" tools. You give them the money for the tool, and when you return it you get back all the money. (If you keep the tool, they keep all the money.)
You could also meander by a local auto shop or machine shop and see if they'd do it. Wouldn't take but 5 minutes.
Thread Tap
Old Mar 8, 2016 | 04:00 PM
woodturner's Avatar
woodturner
I agree, thread tap with a little cutting fluid will do the job.
Old Mar 8, 2016 | 07:08 PM
chase.hollowell
So I bought a die and tap set. Which worked great for the welded nuts. Bought had a hard time getting the old lock thread off from yesterday. But finally got it. Then when I finally got it all done and put the sissy bar on. It's way too narrow. So I had to redneck up some thoughts. And I grinded down the spacers, which took forever since I don't have a vise. But all in all after 2 days I finally got that bitch on!
Old Mar 8, 2016 | 07:12 PM
TUCCI's Avatar
TUCCI
Agreed, as soon as it starts getting tight, back that bolt back outta there and clean those threads. I had a bolt do that on the engine block, the ones that hold the muffler bracket on, man did I back that bastage out and clean those threads.
Old Mar 8, 2016 | 07:13 PM
chase.hollowell
Yes luckily I did.
Old Mar 8, 2016 | 08:10 PM
eaglefan1's Avatar
eaglefan1
Had to do the same thing to my bike when I bought it. I bought a tap and went to town. The junk that came out was nasty. No way the bolts would have threaded and tightened correctly. 20 minute job took a few hours and more than a few beers
Snooplbc
Sep 10, 2015 08:11 PM
stic2it
Dec 10, 2009 03:08 AM
GermanyBert
Jan 14, 2007 10:22 PM
HDF Tech
General Topics/Tech Tips
Dec 21, 2005 01:09 PM
