CB Issue
Old Mar 17, 2016 | 10:45 AM
dang_jayhawker's Avatar
dang_jayhawker
Default CB Issue
I guess not many out there use the CB as I could not find much info when searching. I have an 08 ultra and ride in large groups. We really like to communicate when riding particularly if we get into traffic.
My issue is I can hear just fine through the headset or speakers. When I try to transmit others can barely hear my voice as it is drown out by a squeeling noise. I have tried different mic's from fellow riders with same results. I have played with the settings on the head unit but nothing seems to help. Anyone out there had this issue or can suggest some ideas.
Any help would be greatly appreciated.
Old Mar 17, 2016 | 10:57 AM
zoozoo's Avatar
zoozoo
As you're facing the rear of your bike make sure the CB antenna is on the right side and your AM/FM antenna is the left side.
I was have your problem when I first got my last bike.
Old Mar 17, 2016 | 02:01 PM
dsigrist's Avatar
dsigrist
Just for grins also try plugging your headset into the passenger's connector just to rule out a bad connection up front. If that fails check the connection to your antenna in the tour-pac under the liner.
If all else fails find a CB shop or a friend with an SWR meter and get your antenna tuned correctly.
Good luck!
Old Mar 18, 2016 | 08:28 AM
tankthebiker's Avatar
tankthebiker
Sounds like the SWRs are off. I wouldn't talk on it much until you tune that antenna or you can burn out the CB finals.
Old Mar 18, 2016 | 12:58 PM
larsfum's Avatar
larsfum
I would be willing to bet that you have a bad ground, probably in the CB itself. The squeal is a dead giveaway. If it is not under warranty you can try opening the unit up and visually inspecting the connections from the mic plug to the PC board. There is probably either a loose, or cold solder connection, probably on the ground wire that is not making good contact. Also check the PC board to ground connection while you are on there.
Old Mar 18, 2016 | 01:54 PM
dang_jayhawker
Thank you guys. I will check all these suggestions out this weekend and report what I find.
Long lonesome highwayman
Nov 2, 2018 07:19 PM
xwhyz1959
Oct 6, 2017 12:59 PM
ke5rbd
2014-2024 Touring Models
Aug 13, 2014 05:52 PM
cycleman50
Jul 28, 2012 08:29 AM
Reef Rider
Jun 28, 2010 08:08 AM
