Ohlins 2-2B adjustment
Old Mar 19, 2016 | 11:30 AM
dixonk's Avatar
dixonk
Ya I am wanting to do the ohlins up front as well. Ohlins has never let me down before and I think it can just be chalked up to a really bad service road around the lake and we both took off a couple lbs since last season.
Old Mar 28, 2016 | 02:46 PM
dixonk's Avatar
dixonk
Bringing this thread back again. Finally got some good measurements and need some help. This is from bottom eye to fixed point on the bike:
Total suspension travel: 84mm
Unladen: 247mm
Laden no rider or passenger: 222mm
Solo: 209mm
2up: 203mm
Please help me where do I need to set my sag for passenger comfort?
Thanks.
Old Mar 28, 2016 | 04:08 PM
dixonk's Avatar
dixonk
So if total travel is 84mm and sag with 2 up is 44 is that too far off on this spring or is that within adjustable range? I am assuming I need to go clockwise and compress the spring more?
Old Mar 28, 2016 | 04:19 PM
RKZen's Avatar
RKZen
I think the shock lengths on Howard's site are from shock bolt centers. So the unladen (no load) length should be the shock length for the 2-2B - the 330mm. If the SAG is set correctly (the 28mm), the laden (loaded) length should be the 330mm - 28mm = 302mm. The SAG should be the same for 2up vs solo. Just adjust the preload for that.
Old Mar 28, 2016 | 04:26 PM
dixonk's Avatar
dixonk
I don't see where to adjust preload on these shocks. Also the 28mm was an incorrect measurement as the wheel wasn't unloaded.
Old Mar 28, 2016 | 05:29 PM
qtrracer's Avatar
qtrracer
Free sag is way too much as is rider aboard sag. Tighten spring by adding preload. I'd start at around 25mm rider aboard.
Old Mar 28, 2016 | 06:25 PM
dixonk's Avatar
dixonk
So do you think I should set for rider and leave as that? Passenger is with me 70% of the time.
Old Mar 28, 2016 | 06:50 PM
qtrracer's Avatar
qtrracer
That would be 1 way to start the process. I can tell you that your settings are off solo and waaaaaay off 2 up. It can only get better from here, LOL
Old Mar 28, 2016 | 07:12 PM
dixonk's Avatar
dixonk
Ok I think I got it. Had to crank it about 6 turns but I got the sag dialed in. Will ride tomorrow and see how it is.
Old Mar 29, 2016 | 10:37 AM
dixonk's Avatar
dixonk
I had a great talk with Howard yesterday. This guy really knows his stuff and I can't imagine why anyone would consider another option. He will be helping me get these things perfect. Stay tuned.
pgarbac
Mar 24, 2019 02:44 PM
JimmyDee
2014-2024 Touring Models
17
Nov 5, 2017 10:25 AM
durtyhairy
Sep 18, 2016 02:29 PM
dixonk
May 31, 2016 07:59 AM
kozy22
Mar 29, 2011 02:26 PM
