Welding Header alloy??
Old Mar 18, 2016 | 08:53 AM
journeyman's Avatar
journeyman
Default Welding Header alloy??
What filler rod is being used to weld the header after removing the Cat??
Old Mar 18, 2016 | 01:24 PM
rlh7677's Avatar
rlh7677
Default Welding rod
I've always used electric rods 316 Stainless 1/16 dia. but in a pinch I've also used 6013 1/16 mild steel only thing is it may display some rust in time but mixes well. Sometimes I also use a piece (1/2 strip) of exhaust pipe for a backing on the seams and works well. Any mild steel rod or wire will work as long as your bonding good . Can also torch or wire weld with a mild steel or stainless rod, it's not holding the bike together.
Old Mar 18, 2016 | 01:31 PM
smitty901's Avatar
smitty901
Every one I seen done they used wire.
CWS
Dec 23, 2018 06:05 PM
racedvl
Aug 5, 2015 04:43 PM
ejvette
Jan 18, 2014 08:52 AM
screamer56
Aug 18, 2013 02:13 PM
cavalier2000
Dec 18, 2010 09:23 AM
