I tried the book method over and over again...didn't work out but I think my plates were just stud together and I needed to warm up the engine for them to disengage. Anywho ended up using hippos method.
when adjusting the clutch, the engine should be at ambient temperature. if you warmed it up before you did the adjustment, it'll be off.
that's why I change the primary fluid and do the clutch adjustment first. after that, i'll warm the bike up and change the engine oil.
I don't claim credit for this: It comes from "Hippo" who was a HD Mechanic on the MSN, HTT Tech Talk site but I use it over the HD Shop Manual procedure.
As long as you have opened up Derby cover to check oil level, this procedure makes the clutch adjustment a little quicker IMO.
1. Loosen the clutch cable adjuster and shorten the cable sleeve as much as possible, but dont mess with the lever. Just leave it alone until the 3rd step.
2. Loosen the lock nut on the clutch pack push rod adjuster.
3. Pull in the clutch lever. It should touch the handle bar grip. If it does not touch the handle bar grip back out the push rod adjuster at the clutch pack while keeping pressure on the clutch lever until it touches the handlebar.
4. When the clutch lever touches the handle bar turn in the push rod adjuster while keeping pressure with your hand on the clutch lever. When you turn in the adjuster it will start to push the lever off the handle bar. Back the adjuster out until the lever returns to just touching the handle bar. Do this a couple of times until you know you are at the point where the lever is just touching the bar. When you find this point - back the adjuster out 1/2 turn and lock it down.
5. Adjust the clutch cable to 1/8 slack and lock it down. A nickel works great for this
Buy yourself a cheap 11/16 deep well socket and weld a nut on top of it. This makes the perfect tool for the adjuster lock nut as you can then use an allen wrench inside the socket to prevent the adjuster screw from turning with the nut. Makes it a lot simpler. ( Note from Green Hornet..I use a big pair of curved jaw lockjoint pliers cranked down on the 11/16 socket)
Interesting... I've never heard of Hippo, nor this method before.
I'm sure Hippo knows more than me, but, after reading this method for the first time, it sure doesn't seem any easier to me than the Service Manual method....????
This method does everything like the manual, except for Step 4. Step 4 uses the lever & the grip as a guide to set the clutch tension. It sure seems like more work & more time than just adjusting the nut (tension) once as per the manual.
Have you ever fiddled with your clutch "cable" adjuster or perhaps changed your "Primary" oil ? Having already done both, I'm inclined to think these procedures take nearly as long to write out as they do to.actually execute.
This internal clutch adjustment will be a new trick for this old dog too but I dare say that if you print out the Hippo procedure, by the time you get the lock nut cracked at the clutch spindle, you'll have all the experience and confidence necessary to execute the Hippo procedure in its entirety. JMO.
I tried the manual and I don't think I did it right I want to do it again, so maybe the hippo way is better for me. I am not sure the "feel" for when to back out and then do the 1/4 - 1/2 turn. Maybe I need to be with someone doing it so I know the feel. Maybe that is why I like the hippo way better....
I have used this method alot.its just another tool in the box, another way to skin the cat..lol..I couldn't get my clutch like I wanted it after a few mods were done, tried it this way and got it,never know till you try.
Slack in the cable adjuster, half a turn out at the clutch, a nickel slack at the lever to finish, and I am on my way. That's my easy method, and works out to my liking.
Follow the manual instructions, easy peasey. I could do my street glide in under 10 minutes. Now I don't have to mess with it on the RGU
That being said.
The less you back the adjuster away from the rod the further away your clutch begins to disengage, but once the clutch gets all warmed up if you didn't back it off far enough you risk the clutch not fully engaging.
I found 3/8 of a turn is where I liked to be cold 1/4 a turn off when I did it hot. But I liked my clutch to disengage as early as possible to give me the widest possible friction zone.
Conversely if you back it off too much moving the disengagement point further back to the grip you risk dealing with a clutch that doesn't fully disengage want's to pull hard at a dead stop and is difficult to shift.
Does the bike have to be level to do this or on the jiffy stand fine?
Either is fine but fluid may leak when on the jiffy stand. Upright is easier. If you don't have a way of keeping the bike upright a small piece of wood under the Jiffy stand will help. If you're changing the fluid the bike should be upright to get the correct fluid level.
