Clutch adjusting the easy method
Old Mar 25, 2016 | 11:49 AM
  #31
DanHappy's Avatar
DanHappy
How big of peice of wood? Talking 3/4" or 2 x 4? Not.flid change, just to adjust the cutch. It's a royal pain o get level safely without a jack.
Old Mar 25, 2016 | 01:28 PM
  #32
xltjim's Avatar
xltjim
I don't have a jack or table as I don't have much room. But when doing things where the bike should be level I screwed in a good sized eye hook into the wall stud. Then use a ratchet strap between that and the bikes left side crash guard. Connect strap to eyehook and crash guard, put blocks of wood under kickstand so bike stands just upright, and then just snug up the ratchet strap. Pretty archaic but works for me and hasn't fell over.....yet. Regards Jim
Correction - I believe I connect strap to the left handlebar when I do this. Don't need to be cranked tight, just enough to keep it on balance and from going over.
Old Mar 25, 2016 | 03:19 PM
  #33
vistavette's Avatar
vistavette
2X4 is what I used before I had the EZUp stand. You do need to be level though for fluid chance to ensure adequate/correct level.
Old Mar 26, 2016 | 10:33 AM
  #34
NAILIT RK's Avatar
NAILIT RK
A spark plug socket already has the nut welded to the top allowing an Allen wrench to penetrate through the drive socket
Tampa Fatboy
Sep 29, 2025 11:39 AM
Talldog
Jul 31, 2014 05:08 PM
pt4u2nv
Jul 31, 2013 03:50 PM
pavin
Apr 15, 2011 08:40 PM
wjl24
Apr 23, 2006 03:26 PM
