and... the million dollar question... how much are Howard's 3-3 with the installation kit?
I'll answer.... the 3-3s don't need an installation kit
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
I'm running a set of Bitubos and I'm pretty happy with them. Took me a while to get them dialed in but I think I've found the sweet spot. I'd still love to try a set of Ohlins someday, but I like the Bitubos enough that I will do the forks next before experimenting any more with the rear.
Give him a call and find out. This man is an information specialist. Will answer his phone most any time and has time for most questions. He is a forum sponsor Motorcycle Metal.
You can easily make your own brackets if the ones that come with the shocks don't work with your particular model.
Here is what I used to make the brackets for the remote reservoir
a. (1) 3 foot piece of 1/8" thick, 1-1/2" width aluminum angle
b. (4) #10-24 x 3/4" stainless machine screws
c. (4) #10-24 stainless nylon lock nuts
d. (8) #10 stainless washers
