Abs light on
Old Mar 31, 2016 | 05:34 AM
Randy La Rose's Avatar
Randy La Rose
6th Gear
Default Abs light on
Good morning after my handle bar swap on my 09 FLHX with a new front brake line the abs light is staying on the brakes seem to be OK I thought I bled them properly. How can I fix this. Thanks
Old Mar 31, 2016 | 05:57 AM
markwolula's Avatar
markwolula
Looks like your off to the dealer, and have them bleed brake system with their workshop digital tech tool .. You can bleed brake system on a abs bike, (plenty on here regarding this).. But as you broke the line to install new brake line, air has got into the system, and made its way to the abs module, (ie, fault has accured, abs light not going out when riding).. Brakes will work as non abs bike, until air is removed from module..
Old Mar 31, 2016 | 06:49 AM
SBates08's Avatar
SBates08
Did you by chance turn the ignition on while you had the brake line apart? Maybe to check your hand controls during the bar swap?
Old Mar 31, 2016 | 07:04 AM
Randy La Rose
6th Gear
I was careful not to turn the ignition on till I was all donedone. So no I don't think I touched it while I was swapping out the bars.
Old Mar 31, 2016 | 07:17 AM
SBates08's Avatar
SBates08
Even doing everything the correct way you always run the possibility of getting air trapped in the module. Only way to fix that is a two to the dealer unfortunately.
gtrplyr
Aug 8, 2017 12:13 PM
dwdagen
May 4, 2017 08:54 PM
Manvsdirt
Apr 7, 2017 06:04 PM
Choopy
Apr 24, 2014 12:21 AM
94ruck
Mar 13, 2014 07:18 PM
