Hidden antennae problem
Old Apr 10, 2016 | 03:51 PM
Streetrunner's Avatar
Streetrunner
Default Hidden antennae problem
I added bag fillers to my EG then realized my antennae wouldn't fit so I bought a HD hidden antennae for inside the fairing. The reception is horrible and it differers depending On location. Once in a while it's not too bad but for the most part it is not even close to the reception I got from my external mounted antennae. I have a hog tunes amp, not sure if that makes a difference. I'm wondering if anyone has had any succes with that type or are there any tricks to get it to work better. I followed the direction to the tee
Old Apr 10, 2016 | 04:31 PM
BeavisRules's Avatar
BeavisRules
Where did you mount your amp?
I recently put a hog tunes amp on my bike and the powered hidden antennae would not pick up any stations at all. I mounted my amp directly above the radio and I am thinking that I might want to move it to the side or somewhere else.
Old Apr 10, 2016 | 04:41 PM
mkguitar's Avatar
mkguitar
antennas work best vertical & with a "ground plane"
- on bikes with tourpaks that is the steel plate in the base of the pak. on your car it is the roof, or hood or trunk deck...and to a lesser extent the road
these are hard and fast rules determined by physics.
you can mount an antenna sideways...it just won;t work as well ...as much of the time.
you can remove the ground plane...it just won;t work as well...as much of the time.
if you add an antenna amplifier- you will increase the background noise or static by the exact same ratio as the radio signal.
the best result is a stock antenna which is a 1/2 wave ( the length of the antenna determines the wavelength or frequency that it will pick up).
I use a 1/4 wave rubber stubby from pepboys $12 using a street glide mount
It works pretty good within a 60 or 75 mile radius from town.
when I tour and the tourpak goes on, I use the stock antenna
some guys for a sleeker look, zip tie the stubby so that it follows the saddlebag mount brace inside a SG or CVO fascia, and kind runs along the fender strut
Mike
Old Apr 10, 2016 | 05:06 PM
Streetrunner
I mounted the Amp on top of the Radio. I'm thinking the antennae is just inferior.
Old Apr 10, 2016 | 05:08 PM
Streetrunner
Did the antennae work prior to putting the Amp above the radio?
Old Apr 10, 2016 | 05:15 PM
Streetrunner
Mike
I agree. My shorty antennae worked flawlessly. Unfortunately there's no space to mount it with the bag fillers. I seldom use my tour pack. It sits on a rack in my garage.
Old Apr 10, 2016 | 08:02 PM
Geoff's Avatar
Geoff
I tried a hidden antenna and short stubby antennas. Reception sucked, so I went back to the stock whips.
Old Apr 10, 2016 | 08:11 PM
CVO SG's Avatar
CVO SG
I have the HD hidden antenna on my current SGS and my previous '13 UC, both work just as well as stock ant, with exception of loosing some weather channels. I've had times were I lost cell signal and Pandara stopped, so I switch over to FM. A buddy has one on his SG with a RF amp and has no loss either. Curious why some of you guys experience a signal loss while some of us don't?
Old Apr 10, 2016 | 08:26 PM
'05Train's Avatar
'05Train
Harley hidden here. Nothing's going to work as well as the big mast, but I can live with that. I rarely listen to the radio anyway.
Old Apr 10, 2016 | 08:48 PM
BeavisRules
Yes, it did. I am thinking of taking the fairing off again next weekend and moving the amp to see if it clears up the reception. Currently I put the whip back on and have ran it up under my seat but it is not cutting it either.
Maybe we are getting interference when the amp is so close to the antennae port on the radio?
