First time doing cam swap 09 FLHX!!!
Old Apr 12, 2016 | 03:46 PM
  #41
SBates08's Avatar
SBates08
Originally Posted by harleycharlie1992
most likely will not need any clutch work with just the cams, and tune, try it first before investing in any clutch stuff, thats my opinion,
I think your right with those cams. I was giving a better although costlier alternative to the heavy duty clutch spring.
Old Apr 12, 2016 | 03:50 PM
  #42
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
A hot stick in the eye, is better than that spring!
Old Apr 12, 2016 | 03:51 PM
  #43
SBates08's Avatar
SBates08
Yessir and I learned it the hard way.
Old Apr 12, 2016 | 03:52 PM
  #44
gipper's Avatar
gipper
SAME HERE!
Old Apr 12, 2016 | 06:08 PM
  #45
otto76689's Avatar
otto76689
besides the hard clutch pull, what sort of issues does the screamin eagle clutch spring cause?
Old Apr 12, 2016 | 06:19 PM
  #46
MikeTD3's Avatar
MikeTD3
I went with a 37871-98A spring in my 107", no slippage and the pull is fine.
Old Apr 12, 2016 | 06:46 PM
  #47
just plain john's Avatar
just plain john
Ok all, I've offered to loan my cam tools to otto, but our displacements are different. I have the Heartland tool that pulls and installs the inner bearing, he should be ok shouldn't he?
Old Apr 12, 2016 | 07:25 PM
  #48
just plain john
Aren't inner cam bearings the same regardless of displacement? I've had my Heartland cam tools a couple of years and my set doesn't look like what they're selling now.
Old Apr 12, 2016 | 08:11 PM
  #49
harleycharlie1992
they are different depending on year late model bikes have a larger diameter brg, early model, (I think its 06 and earlier for dyna, 07 and later for touring, have different size) thats only difference though, but it is two different tools. ( or one with the adapter)
Old Apr 12, 2016 | 08:40 PM
  #50
otto76689's Avatar
otto76689
I have the correct bearing installer tool, I really only need the bearing puller. Do you think Johns puller would work?
