My HD pump that I got with my RG leaks all the air out when you disconnect it. Do any of you know if you can buy a replacement seal for the part that screws on to the Shrader valve?
ORIGINAL: sknyfats
and you CAN use it on other things - like tires, etc - I tried this last weekend - but, you'll be pumping a LOT for the higher PSI items.
Yes, you can use it for tires. BUT a word of warning, if youdo so, you stand a chance of blowing the little o-ring inside the thing if you pump like you normally would pump up a tire. And you can't find that o-ring anywhere. Ask me how I know.
I currently have an HD pump and it works great. I had a Progressive pump with my last bike (which I left in the saddle bag when I sold it). It worked good as well.
