check engine light
Old Apr 21, 2016 | 10:04 AM
Harleyrider1648's Avatar
Harleyrider1648
6th Gear
Default check engine light
Check engine light has been coming on very sporadiclly. I noticed it come on when really accelerating fast until i let the throttle go. Also when accelerating slowly untill i give it more throttle. only does it once in awhile. No stored codes. it just had the twenty thousand mile service and a new hd battery. Any ideas?
Old Apr 21, 2016 | 11:12 AM
dodger413's Avatar
dodger413
this is purely anecdotal .........
one of my wise *** friends pulled my spark plug wire at the spark plug but left it lose and sort of connected.
till i discovered it, it would throw the check engine light under hard acceleration intermittently, very frustrating. BUT it did leave a code. "accelerometer error" it told me
after reconnecting the plug wire firmly, it never showed its ugly head again
Old Apr 21, 2016 | 11:27 AM
bdtaylor1979's Avatar
bdtaylor1979
You can check your codes this way,
https://www.hdforums.com/forum/dyna-...lear-them.html
Old Apr 21, 2016 | 11:44 AM
Jay Guild's Avatar
Jay Guild
As a guess I would say it is missing on hard acceleration. Check plugs and wires. Could be a lot of things.
Old Apr 25, 2016 | 10:01 AM
Harleyrider1648
6th Gear
up date: now the check engine light comes on after starting for about thirty seconds. doesnt seem to come on after that. still no codes
Old Apr 25, 2016 | 10:32 AM
todd-67's Avatar
todd-67
This could be a number of things but it sounds like the TPS sensor on the throttle body. Pull it apart and clean everything up. Then put dielectric grease on it before reassembly. You may also want to check your plugs. You said you already went over the wires.
Old Apr 25, 2016 | 10:37 AM
Harleyrider1648
6th Gear
Yeah I checked it all over. I'll try the tps. It just had its 20k service and road flawlessly in Daytona. This is a new problem.
Old Apr 26, 2016 | 05:48 AM
billqbiker's Avatar
billqbiker
Had similar problem with my 03 Road King, and it turned out to be loose spark plug wires.
Good luck!
Old Apr 26, 2016 | 07:34 AM
tv7son's Avatar
tv7son
That to me sounds like you still might have a History Code stuck in there. My 07 used to do that to me. The code will have a H attached to it.
tripacer1
Aug 31, 2012 08:32 AM
mad34b
Mar 26, 2011 07:21 PM
Rubber Slinger
Apr 2, 2010 09:17 AM
joearizona
Jul 10, 2009 12:40 PM
Softtail Bob
May 11, 2007 11:36 PM
