Need quick help....check engine light is on.
Old May 11, 2007 | 10:46 PM
Softtail Bob's Avatar
Softtail Bob
Default Need quick help....check engine light is on.
Well we are going to head out in the morning for a 900 miles ride so I changed all my fluids and when I got the bike warmed up to check the fluids everything looked good. The oil was about 1/8" over the full line when hot but that should not be a problem. I take off to go by my brothers and the bike is running sluggish and the check engine light and the battery light come on so I turn around and head home. i looked everything over and don't see any problems. I went thru the Fuelpak settings and everything looks good. When changing the fluids I also added the digital dipstick and the Chrome bridge from kuryakyn. what could it be?
Old May 11, 2007 | 11:18 PM
Rick 547's Avatar
Rick 547
Default RE: Need quick help....check engine light is on.
Check to make sure your spark plug wires are good and tight on the spark plug.
Old May 11, 2007 | 11:36 PM
cowboyglide's Avatar
cowboyglide
If the new bridge is around the spark plugs or wires you may me grounding out from a pin hole in the plug wire or plug area. I would also check to make sure my hot wire and ground wire from the battery are good and tight.
Grunge Munkee
Jul 28, 2017 01:45 PM
Harleyrider1648
Apr 26, 2016 07:34 AM
Fierofly
Exhaust System Topics
Feb 26, 2012 04:03 PM
mad34b
Mar 26, 2011 07:21 PM
tgaetto
24
May 25, 2007 12:59 PM
