SE clutch spring
Old Apr 21, 2016 | 10:19 PM
hockey8787's Avatar
hockey8787
Default SE clutch spring
For those of you that are on the fence about weather or not to install a SE clutch spring on your bike that may be having trouble with the clutch slipping still after adjusting, i say DO IT its easy to install and a BIG improvement over the stock spring, no more slipping!! Hope this helps someone else!!!
Old Apr 22, 2016 | 06:08 PM
ORradtech's Avatar
ORradtech
I agree, upgrading to a stronger clutch spring is worthwhile.
I went one step further and upgraded the clutch as well. Went with the Energy One +1 kevlar clutch with the heave duty spring. What an amazing difference over stock! 11% more clutch surface and 10% stronger spring. The wife and I are not small people and I get zero slip unless I intend for it to.
I was concerned that the clutch pull with the stronger spring would be uncomfortable, as I have a cable, not hydraulic, but it is not.
Old Apr 22, 2016 | 06:43 PM
SBates08's Avatar
SBates08
Wait about 2 months and you'll have a Popeye left forearm. Not to mention the damage that SE spring will cause to your clutch cable and other moving parts of the cable assembly (inside the perch). Been there and done that. Smartened up and installed the AIM VP95LT. No more slip and no more hard clutch pull.
Old Apr 22, 2016 | 07:25 PM
Smokey Stover's Avatar
Smokey Stover
I've had the HD SE spring for about a year and a half now. It did feel like a hard pull at first but after the first couple months it seemed to, Break in so to speak. Feels natural/normal to me now.(No Popeye forearm yet) It does hook up really good and no more slipping rolling on th throttle to pass (fully loaded with wife and tourpak)in 5th or 6th. I have to say I did install a new Diamondback cable with it just to be safe. Maybe someday I'll upgrade to a VPC but for now I'm good. Just inspected primary and all is well.
Old Apr 22, 2016 | 07:39 PM
02fx4dude's Avatar
02fx4dude
I put the SE spring in 3 years ago, didn't have clutch slip problems, just didn't like the squishy feel of the stock spring. Feels better, no cable problems or broken levers, no popeye arms.
If you don't like it take it out and throw it on ebay for a few dollar loss, lesson learned.
Old Apr 22, 2016 | 07:43 PM
qtrracer's Avatar
qtrracer
On most(95+%) touring bikes there is NO need to go to the SE Heavy(380) spring. The Aim 340 spring or the stock rushmore spring should do the job.
Old Apr 23, 2016 | 05:04 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
We use Barnett springs here.
With the large high-output engines, we use the VPC92T in conjunction with it.
Scott
Old Apr 23, 2016 | 07:03 AM
todd-67's Avatar
todd-67
What is the # rating for the 2 barnett springs? The website does not list the specs that I could find.
billablehours
Jan 18, 2016 09:13 AM
retired by accident
Jul 5, 2015 09:32 PM
satman
Nov 6, 2014 05:12 AM
Clifford05
Mar 27, 2014 09:31 AM
FLHXXHLF
Jan 9, 2009 08:25 PM
