Fuel Moto pushrod adjustment
Old May 2, 2016 | 06:34 PM
skydude426's Avatar
skydude426
Originally Posted by Bmusg
Fuller disclosure, getting the jam nuts loose wasn't the biggest issue. Breaking the lower pushrod (shorter piece) loose from the black threaded piece was the challenge. Once it was out, I was able to use a socket on one piece and a box end wrench on the other. I thought for sure it was going to twist off. I read on the other forum that some guys end up taking their lifter blocks loose to get more room. There seemed to be a consensus that Loctite was optional, works for me. If I were dead set on Loctite, I definitely wouldn't go past blue.
Got ya. I broke the locknut loose and dropped them in place before putting the rocker support plate back on so I wouldn't have to take the push rods apart. I'll bet getting the threaded rod out of the bottom piece would suck with lock tite on them. I don't remember if I used it on the bottom piece. I don't think I did, just a little dab on the locknut after adjusting them.
Old May 2, 2016 | 07:13 PM
liquidr1's Avatar
liquidr1
Originally Posted by SBates08
Yeah that's pretty close. My S&S are the same. What about the Rockouts, have you thought about installing them? They took care of my top end noise.
I already have them installed. Thats why im thinking i need to add a few more flats on my adjustment
Old May 2, 2016 | 07:36 PM
RatPwrd72's Avatar
RatPwrd72
I don't have the 222 cams, but my Andrews 57H's make a noticeable noise in the intake. I've done several of them and they all sound the same. Aggressive ramp is what I think you're hearing.
Old May 2, 2016 | 07:38 PM
sanman4ever's Avatar
sanman4ever
Turn up the tunes...
Old May 3, 2016 | 10:34 AM
liquidr1's Avatar
liquidr1
Ok guys, Bob at Fuel Moto just responded to my email. He says to go 4 turns and 5 flats to add more preload on the woods lifters. He also said the woods lifters will bottom out at 6 full turns with their pushrods.
Old May 11, 2017 | 06:29 PM
mhenness's Avatar
mhenness
2nd Gear
Default Loctite
I use the blue Loctite every time. Use a heat gun to melt the Loctite until soft.
memphisharley
Jan 2, 2018 06:03 AM
Teardrop
May 20, 2012 12:52 PM
eagles
Exhaust System Topics
15
Apr 17, 2012 09:48 PM
MILLER41143
Jan 29, 2012 10:51 AM
scottdoege
Feb 18, 2011 03:05 PM
