Is the display unit water proof or lets say can it handle some rainy weather.
I hose mine down regularly when washing the bike & haven't had any issues.
__________________________________________________ ____ For ROCKOUT information & purchasing please click the LINKSbelow...
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
According to the box it is water and dust proof. And looking at the unit, it seems like it is pretty well sealed.
And when I mounted it, I drilled as small a hole as possible through the dash, and then pushed the unit up as far as I could so the strain relief sort of acts as a washer to seal the hole. If any water gets through when I wash it, it can't be much.
