Which jack?
Old May 8, 2016 | 07:17 PM
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
My Sears yellow jack broke with my bike up in the air. Took me and 3 buddies to get it down. Jack was dragged to the curb for the trashmen to pick up. Spent the extra jack (pun intended) for a J&S and never looked back. Best accessory I ever bought.
Old May 8, 2016 | 07:27 PM
hattitude's Avatar
hattitude
Originally Posted by twp98
Ok I am wanting to get me a jack. To help with maintenance and cleaning. I have been looking but I don't know which on would be the best. I'm just wanting to just get it off the ground. I don't think I want to lift it real high.
Might want to rethink the part about " I don't think I want to lift it real high.".....
The higher, the better, and easier on your back...... especially as you get older
However, I used a Sears jack for several years on my softail, until I got a bagger. The extra weight exposed it for how unstable it was...
J&S is an excellent jack.... replaced the Sears with one, and still use for certain things... even though I now have a lift table...
If your young, limber and just want to get it a few inches off the ground, like the scissor jack you show a pic of, I went with the black Widow scissor jack. I use it on my lift table when I need to get a wheel off the ground. It doesn't lift too high, but sure is stable.
http://www.discountramps.com/motorcy...FYNsfgod25gBUQ
Black widow jack in service with my softail....
Good luck with your decision...
Old May 8, 2016 | 07:28 PM
hemi1300's Avatar
hemi1300
Anyone recommend j&s yet? No searching and reading reviews needed, just order it! Built like a tank and lifts my street glide effortlessly
Old May 8, 2016 | 07:47 PM
ORradtech's Avatar
ORradtech
J&S is the way to go. Saw a friend of a friends Ultra Classic on one and he could roll it around his garage, lean against it and even rock it with it 18" in the air and it was rock steady.
I have one similar to the ones you show, forget where I got it, and it scares me when it gets more that a few inches up.
Spend the money for the J&S, you wont regret it!
Old May 8, 2016 | 09:06 PM
rscott's Avatar
rscott
J&S by far the best
Old May 9, 2016 | 06:19 AM
LiiT's Avatar
LiiT
Howdy neighbor.
The J&S are great jacks no doubt, but if your budget is limited (like mine) the Harbor Freight has worked well for me for a few years now. I use it mostly to help get the bike up where it's easier to clean.
Old May 9, 2016 | 06:23 AM
RKZen's Avatar
RKZen
Not only do I use my J&S for cleaning and maintenance, but also to move around easily and store my King in the garage. No problems with it and the T-handle makes moving around simple.
Old May 9, 2016 | 06:37 AM
FX4's Avatar
FX4
J&S...
Old May 9, 2016 | 06:38 AM
Keithhu's Avatar
Keithhu
Old May 9, 2016 | 06:43 AM
roadkingdean's Avatar
roadkingdean
Default Screw type
I would suggest a screw type jack as you can let the bike down slow and no worry of the hydraulics going bad on you over time. no oil to add or leak
