What would you do-why?
First - 2010 ultra classic $15,000 9,900 miles. Screaming eagle stage 2 installed with 255 cans. Makes it a 103 that i understand is more potent than the stock 103, or so I've heard. V&H , and tuner.
Second bike- 2012 ultra classic $15000 6000 miles. Stock 103. Rush exhaust and power commander, otherwise stock.
Do I go for newer with less miles or a little older with not many more miles and the motor upgrades? What would you?
Btw- ones dark blue ones black so not a major difference their either.
1st off,when talking 6k or 10k miles that such lows miles on either bike it make no diff at all to bother talking about so pout that to rest.
If you just talking buying either of those 2 bikes its hands down the 2012 for the same money/$15k because its 2 yrs newer and is mostly stock accept for stage 1 type mods that many HD owners install for the same so little less likely to be abused/beat on vs the 2010 with larger top end installed with perf cams too thats may be bit high on price from seeing a few clean 2010's not sell in $12.5-13k range.
The 2010 has had money put into it for new top end & perf mods but it doesnt increase book value in most people eyes .
And also keep in mind adding that type perf mods to the 2010 means the bike will be very likely hammered on more more then avg too because guys that dont hammer their bikes & or need more power don't normally add cams and larger displacement top end just to ride conservatively most of the time & not hammer it fairly.
Of the those bikes it would a no brainer to go with the 2012 for me.
BTW,i see some rec for you to try for 2014's,well i dont think you will normally see low mile mint cond stock or stage 1 only moded 2014 Ultra's going for 15k unless there's a reason like being a high mile bike for the yr or someone has to make a quick sale due to needing money for an emergency or divorce,etc.
Scott
Just humble opinion
But to answer the OP, I would go with the 12, 2 years newer, same price. But I wouldn't worry about the minor mods to the 10 either.
